Go to Post Take it from a team that mastered tank treads and still hasn't built them in over a decade - it's not worth it. - Isaac501 [more]
Unread 10-01-2015, 14:20
GearTech GearTech is offline
FRC #0108
GearTech is an unknown quantity at this point
Exclamation RoboRIO imaging error
I've updated the 2015 Suite
I've also updated the firmware on the RoboRio
When I tried to re-Image it gives an error:
Unable to configure the settings. Unable to comp!ete (not spelled incorrectly) operation because of unexpected error:
Property Node (arg 1) in
>RoboRIOImagingTool.lvlib:Config Settings.vi-
>RoboRIOImagingTool.lvlib:Reconfig Device.vi-
>RoboRIOImagingTool.lvlib:ImageManager.vi-
>RoboRIOImagingTool.lvlib:ImagingToolMain.vi
We have already tried to Turn it off and turn it back on.
Unread 10-01-2015, 14:44
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Re: RoboRIO imaging error
We are having a similar problem. I have been unable to figure out how to factor reset the RoboRIO in order to start over.
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 10-01-2015, 17:03
partounian's Avatar
partounian partounian is offline
FRC #0599
partounian is an unknown quantity at this point
We've been having the same exact error, we've tried 3 different laptops (all W7). I've spoken with NI for a few days and after trying an insane amount of things, they ended up shipping another roboRIO but we're still having the same issue.
The order of installation attempted for the new clean roboRIO:
-Clean install of Labview
-Updated firmware
-Attempt to install (w/ and w/out safe mode) via USB as suggested.
Attempts to get connection over ethernet and wireless have always failed, but USB worked fine after one successful image on the old roboRIO (that was done by a friend's personal computer over ethernet).
We have tried:
-Changing IP settings
-Using MAX (unable to detect (old) roboRIO as remote system/haven't tried with the new roboRIO as no reason for it)
-Checked all connections/placement
-Direct connection to roboRIO
-Connection through router wired and wirelessly
-pinging through cmd has worked sometimes
-using Putty (not sure what we did with it)
Will post more attempts when they come to mind.
Unread 10-01-2015, 18:39
Did you try rebooting your PC that is doing the imaging?
Unread 10-01-2015, 20:39
urg8rb8 urg8rb8 is offline
FRC #0108
urg8rb8 is an unknown quantity at this point
I don't remember rebooting the PC. But we used a Windows 8 machine... do you see an issue with that?
Unread 10-01-2015, 21:54
Windows 8 & 8.1 were used by some of the Beta testing teams and should work fine.
Unread 10-01-2015, 22:08
These issues weren't encountered during the beta, so the support engineers are working through what may be going on and what may work to fix it.
At this point, there are two issues that they are worried about. If the power connector to the roboRIO were to be loose, the power may be lost during the imaging operation. That complicates the imaging process since it may now be necessary to go into safe mode.
The other issue seems to be related to timeouts during the imaging on some laptops. Please continue to work with the engineers so that we can get to the bottom of this.
Greg McKaskle
Unread 11-01-2015, 01:10
FRC #0108
Greg McKaskle
How do we contact the support engineers?
Unread 11-01-2015, 08:07
Good question.
ni.com/frc is the primary landing page, but it is sort of busy.
The overview tab contains an FRC 2015 section on the left. It tells you different options for free support. The phone # listed is answered by the engineers.
The third tab leads to the online forums which are answered primarily by the support engineers.
Greg McKaskle
Unread 11-01-2015, 16:26
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
I got hit with the same problem with a roboRIO and PC that had been imaged a couple of time with beta (roboRIO was not a beta one, was one of the AndyMark early deliveries).
What was different this time (besides the versions) was that I had the ethernet cable attached to the roboRIO and a radio (even though I was imaging over the USB). On a hunch, I disconnected the roboRIO from the Ethernet, cycled power on the Ethernet, and the reimage worked.
Don't know if it was coincidence, but if you have the roboRIO connected to the Ethernet, try disconnecting it while imaging.
Unread 11-01-2015, 16:52
FRC #0108
Hmmm thanks will give that a try! We had both Ethernet and USB cables plugged in simultaneously.
Unread 12-01-2015, 04:34
idooriane idooriane is offline
Electrical Head Team
FRC #1943 (NeatTeam)
Team Role: Electrical
idooriane is an unknown quantity at this point
We had the same problem on Windows 8.1. So we try on other computer that runs Windows 7 and it works. So if you still have the problem try the solution we suggested it may works.
Ido Oriane
FRC #1943 NeatTeam (2012 - Present)
Electrical Head Team #1943 (2013 - Present)
Programming Team C++ #1943 (2012 - Present)
Media Head Team (2012 - Present)
Unread 15-01-2015, 00:29
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
I have downloaded and installed the FRC2015 update but I can't find any icon or shortcut that leads me to the Imaging tool? I searched c:\Program Files, c:\Program Files (x86) but I can't find it. Where is it? BTW, we are using Java this year if it makes any difference.
Unread 15-01-2015, 00:39
mikets's Avatar
Software Engineer
Never mind, I found it. It's in C:\Program Files (x86)\National Instruments\LabVIEW 2014\project\roboRIO Tool
Unread 16-01-2015, 10:07
partounian's Avatar
FRC #0599
I've managed to fix this error. The laptops I've attempted to use are school laptops and they did not have any connection successfully until now. (I've only attempted another student's personal laptop which worked successfully.) The school laptops were running Symantec protection and even if you disabled the settings, they actually wouldn't be disabled, even though they seemed to be.
FIX: I simply uninstalled the Symantec software and it works now.
