Go to Post But before we jump to conclusions, I'll wait for kickoff and the manual. ;) - BrendanB [more]
Unread 11-01-2015, 09:11
Jared's Avatar
Jared Jared is offline
RoboRIO Red Power Light
Yesterday, we had the power light on the roboRIO turn red a few seconds after we turned it on. The roboRIO was connected to some speed controllers in a configuration that had worked previously, but randomly stopped working.
I haven't found any documentation explaining what a red power light was, so I was wondering what it meant, and how we could prevent it from happening again. We were able to fix the issue by unplugging everything but power, starting the device, then plugging in only two speed controllers. We did not attempt to plug in all the speed controllers because we didn't need them all, and we did not want the issue to come back.
Here are some details:
With the red light on, we could not communicate with the roboRIO, but the lights on the ethernet port would sometimes flash.
When the robot is switched on, the power light is green for a few seconds, then turned red.
The power light is distinctly RED, not orange. I've seen it orange before, and this was red.
The voltage at the roboRIO power connection while this was happening was 12.5 volts
When we pushed the reset button, the device power cycled, but the light remained red.
The roboRIO seemed to be slightly warmer than room temperature, but had been on for several hours at that point, so this might be normal.
When we booted into safe mode, the power light stayed green.
Unread 11-01-2015, 09:33
Re: RoboRIO Red Power Light
led info is at http://wpilib.screenstepslive.com/s/...uick-reference and the roborio user manual https://decibel.ni.com/content/docs/DOC-30419
The power tab of the driver station will tell you which of the power rails is experiencing the power fault. If removing the speed controllers fixed it, it is probably the 6v rail and you have a bad speed controller or cable.
Unread 11-01-2015, 10:07
Jared's Avatar
Thanks, I was looking at a different website that didn't have the red code, so I missed that. Strangely, I could not connect to the robot (usb or ethernet) when the red light was on.
