Go to Post So, FIRST is turning into the For the Inspiration of Science and Trains? That makes sense... Not a whole lot of re-branding will be needed.... - dqmot17 [more]
Unread 10-01-2015, 18:14
Quantum Byte's Avatar
Quantum Byte Quantum Byte is offline
Lead Programmer
AKA: Domenic
FRC #4776 (S.C.O.T.S. Bots)
Quantum Byte is an unknown quantity at this point
Multiple Autonomous Programs
Hello all,
I am currently trying to think of a way for my drivers to pick what autonomous code to use before a match, preferably queuing. I was wondering what would be a good way to do this. I was thinking that while the robot is disabled, I display what autonomous to pick in the SmartDashboard. What do you guys think?
Unread 10-01-2015, 19:25
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Multiple Autonomous Programs
Yup, the SendableChooser object in C++/Java/Python works great for this sort of thing.
Unread 10-01-2015, 20:23
Lead Programmer
AKA: Domenic
Thanks man, works great!
Unread 11-01-2015, 09:32
wendells's Avatar
wendells wendells is offline
FRC #2185 (RAMAZOIDZ)
wendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to all
One of the most important factor in this game is the PROGRAMMER. According to the Alliance the programmer must be able to redo their autonomous game to suit the alliance.
What do you think?
Unread 11-01-2015, 09:44
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
What do you think?
Yeah, I like the variety that the autonomous code must accommodate.
For that reason, I'd like to utilize my experimental auto scripting language, as I think it will be important to quickly modify auto modes during an event.
I was even considering some kind of graphical interface to quickly build and modify auto modes. Like maybe have a diagram of the field, and simply plot points that the robot should go to, and add actions at each point. It's certainly something I'll experiment with.
Head Programmer / Driver
Unread 11-01-2015, 10:13
one_each one_each is offline
FRC #4057 (KB Bots)
one_each is an unknown quantity at this point
We will be using some kind of scripting this year, most likely Lua, for auton. The drive team will need some kind of UI to select what to do, but it needs to be quick and easy for them. The programmers will have more time to write and debug complex interactions then the drive team will have just before a match. It is my hope that the programming team will get it down to just a handful (<=5) of SendableChooser objects.
Unread 11-01-2015, 17:33
Randaline's Avatar
Randaline Randaline is offline
AKA: Abby
FRC #0716 (The Who'sCTEKS)
Randaline is an unknown quantity at this point
In past years, our team has put 2 mechanical switches on the robot, and for every configuration of the switch (ON ON, ON OFF, OFF ON, OFF OFF), you could have a different autonomous code. All you had to do was put the code in an if statement and write a notecard out to the drivers explaining what flipping the switches would do for the autonomous. You could have as many as you wanted, but 4 seemed to be the magic number for us. This method worked the best when we didn't have any programmers, but a team full of mechanical kinds of people.
However, we've been experimenting in recent years with the SmartDashboard, and if you want a more updated method, picking straight from there is the way to go.
Unread 11-01-2015, 22:10
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
Just today our team put together a way of selecting autonomous programs through the SmartDashboard. We're not using a command-based framework, so we made it work using pointers to functions. You just make a function for each possible autonomous mode, use a SendableChooser to pick a function, and have the actual AutonPeriodic function just run the chosen function. Anyone who's curious can check it out on github here.
Function pointers are unholy magic though, so stick to Commands if you're not lazy and old-fashioned like us.
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
Unread 11-01-2015, 22:24
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
So much work!
We just used A and Y to swap between modes.
https://github.com/1684Chimeras/2014...utonomous.java
Unread 11-01-2015, 22:45
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Originally Posted by Arhowk View Post
So much work!
Yep. Just put some selection code in the disabledPeriodic() looping method and have some cycle button on your joystick be used to cycle through the Auton modes. It would probably be a good idea to have some text display the currently selected mode on the dashboard too. I never understood why people made more work by actually mounting switches on their robot, this is so easy to implement.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 11-01-2015, 22:50
alopex_rex's Avatar
AKA: Scott Morton
So much work!
I like using the SmartDashboard, rather than joystick controls, because there's no button mapping to keep track of. We can add as many auton programs as we want and add each to the chooser with a single line of code. Anyone using the driver station can see the list of the choices, with names/descriptions, and click one to choose it, without having to know the button scheme (or even have a controller). Also, compared to your code I have to say it seems a little simpler; we don't even need an array to keep track of all of our auton programs. (Although of course I have not ruled out the possibility that your code is simply more fancy than ours.)
Last edited by alopex_rex : 11-01-2015 at 22:54. Reason: if a post is edited on a forum, and no one saw it beforehand, was it really edited?
Unread 13-01-2015, 12:34
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
scripting via LUA?
jeez, have fun friend. LUA is a major pain, speaking from personal experience.
Unread 13-01-2015, 14:12
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
We used the driver station digital inputs to select our autonomous mode last year. We originally had a physical 3-stage switch on our driver station which was wired into the Cypress which was connected to our driver station laptop, however, our Cypress stopped working so we literally just clicked an individual digital Input on the driver station, under "D I/O" and referenced each digital input in our autonomous code, so different digital inputs would correspond to a different auton mode. I mean....it worked...
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 13-01-2015, 14:23
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Sparkfun has a great 10 position switch and a breakout board for it that would make it quite simple to add up to 10 different Auto modes to you drive's station.
You can use the TI LaunchPad from the KOP as another HID device and connect all 10 inputs to it if you needed that many.
Unread 31-01-2015, 12:31
Lead Programmer
AKA: Domenic
Sorry to revive this thread after a couple weeks, haven't checked this thread in while
Anyway, i have made a system in java where it loads a autonomous mode inheriting a base class, makes it pretty simple to create. It also loads depending on the robot, since our team uses multiple robots
https://github.com/SCOTS-Bots/FRC-20...peration/auton
