Go to Post Often heard exchange in the shop: "The physics don't allow that." "But it's so cool!" - MBF [more]
Unread 10-01-2015, 18:11
Hsifeulbhsifder Hsifeulbhsifder is offline
Programmer
AKA: Zaeem Mohamed
FRC #5428 (Breaking Bots)
Rookie Year: 2015
Hsifeulbhsifder is on a distinguished road
Regarding getPOV()
I know the POV has to do with the directional-pad- on a gamepad, but what is the API in terms of using it?
And more importantly, how may I run commands based on POV input?
Unread 10-01-2015, 18:21
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Regarding getPOV()
Here's the API:
getPOV
public int getPOV(int pov)
Get the state of a POV on the joystick.
Specified by:
getPOV in class GenericHID
Parameters:
pov - The index of the POV to read (starting at 0)
Returns:
the angle of the POV in degrees, or -1 if the POV is not pressed.
Unread 11-01-2015, 10:14
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
So, if I wanted to get the value of left on the directional-pad, what value must i check for?
Unread 11-01-2015, 11:39
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
This is something I've been wondering too. Did this method exist prior to 2015? Because I seem to recall that we had to use the getAxis() method before.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 11-01-2015, 12:15
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
i haven't messed with it but I would try for you is just storing the output of the method in a variable and doing a System.out.println(variable); just so you can see the values it outputs in console (or add it to smartdashboard)
Unread 11-01-2015, 15:34
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
It should return -1 - 7, with -1 being nothing pressed, 0 being top, 1 being top right, 2 being right, and progressing clockwise to 7 in top left.
My FRC History:
Unread 11-01-2015, 15:59
Have you tried it? That's not what the docs posted above say.
Unread 11-01-2015, 18:50
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
Disclaimer: everything i say is for an xBox controller.
When I was trying to get a map of the button and axis numbers yesterday, I found that the dPad wasn't an axis or a button and the triggers were now separate axes. In the past, both triggers had been considered 1 axis, and one added to a value and the other decremented it. In the past, we've used axis for the dPad, but it only worked left and right. Here's hoping this new implementation will work for up and down too. When I saw the dPad didn't work, I assumed it just didn't work, I didn't try getPOV(), because I don't know what a POV was. I'll see if i can figure it out tomorrow!
Unread 11-01-2015, 19:12
Have you looked at the display on the USB tab of the driver station? It makes it much easier to find out how things are mapped.
Unread 11-01-2015, 19:50
AKA: Sparks
I did not. I didn't know that was an option. I just wrote a simple iterative robot program that printed out when i was over .5 on an axis or pressing a button. I had 10 axes and 15 buttons and caught everythign.
I should probably take a better look at the tools available to me before I solve a problem next time. And I'll examine that tomorrow as well. Thanks!
Unread 11-01-2015, 22:22
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Sorry, I see that now.
My FRC History:
Unread 13-01-2015, 23:03
AKA: Sparks
On the x-box controller, the dpad is a "POV". It functions exactly how the doc says using the method call which does not require an argument. up is 0, right is 90, down is 180, left is 270, and if its unpressed, its -1. You do get the 45 degree intervals between those I listed as well.
