Go to Post I've always believed that being who I was will not limit me to who I will be. That's what keeps me trying to learn more and become a better person. Otherwise I would've settled being someone ordinary and not care about anything around my life. - Ken Leung [more]
Unread 11-01-2015, 10:36
walterev walterev is offline
FRC #1758
walterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to all
roboRIO Imaging Issues
I have not seen another instance of the issues we are seeing with our roboRIO on CD. We have a ticket with NI, but hoped to get a better understanding of the environment. Essentially, we have not been able to update the image on our device. We use C++
1. Update firmware: no problem
2. Update image via USB: problem Click image for larger version
3. Tried updating via the Ethernet port and also from another computer but with similar results. I did not log the status light patterns, but will do so later today.
4. Contacted NI, who provided a recovery tool to use before imaging: same result
5. NI suggested using NI MAX to format the device before imaging: same result
6. Attempted to deploy anyway to see if image possibly had installed but received an error indicating authentication problems with lvuser (note: SSH is enabled) Click image for larger version
7. Checked roboRIO via web interface and there is no lvuser account
8. After a subsequent attempt, the admin account was missing as well.
So my questions:
What accounts are needed for a successful installation?
Are these created during the image installation or as part of another process?
Is it possible that the installation is failing due a permissions problem at a lower level?
I will continue to work with NI but wanted some feedback from you guys.
Thanks,
Walter Everett
Mentor: Team 1758
