Go to Post FIRST... (is) just as human as we are. (except now in game hint season when they are big meanies) - Tetraman [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 07-01-2015, 10:19
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: Best Drivetrain options
All questions teams should ask before for selecting a drivetrain:
holonomic or tank drive ?
what size wheels , ground clearance ?
what is the desired speed and torque ?
single speed or shifting gearbox ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 07-01-2015, 10:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by Lil' Lavery View Post
How is it less complex than mecanum?
I'm guessing most people think mecanum is complex because thinking about how it moves can hurt your brain initially. And maybe they're worried about getting the wheel configuration wrong. In reality the most complicated thing is making sure all your wheels hit the ground most of the time, and that weight is relatively evenly distributed (side to side, at the least).
Worst problem I ever had was when someone pulled the PWMs on a mecanum robot we'd misplaced the code for. Working out which PWM was for which wheel was somewhat frustrating for about 30 minutes or so.
Unread 07-01-2015, 10:29
Or both (octocanum). Or neither (H slide).
Unread 07-01-2015, 10:47
Here's a procedure that might speed things up a bit.
Put the bot up on blocks.
Command pure forward (FWD), then strafeRight (STR), then rotateClockwise (RCW)... and for each command, record which direction each wheel is turning.
Unplug the PWMs and reinstall them per the attached chart.
Name:	mec chart.png
Unread 07-01-2015, 10:48
pfreivald's Avatar
AKA: Patrick Freivald
This will be the first in quite a few years that we do not use octocanum.
Nor are we using the drop-center WCD-ish drive we prototyped over the summer/fall.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 07-01-2015, 10:59
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I went through the following decision process:
What technologies do we have a comfortable level of experience with?
Tank - yes
Mecanum - yes
Shifting - yes
Single speed -yes
Slide/H/octanum - no
Swerve - no
Advantages synergistic with proposed play style?
Mecanum - translation, non-rocking base of support
Tank - non-rocking base of support, (arguably) lower weight
Shifting - none, divided field means acceleration in short runs will be most important feature
Single speed - lightness, simplicity, low cost, with so many motors available we can add power until we like the performance
Since mecanum's classic disadvantages aren't a serious issue with recent upgrades from mecanum wheel makers and the lack of robot-robot defensive play (at least in my humble opinion) mecanum, with single-speed transmissions, won out for us. YRMV given different team experiences or preferences.
We already have a prototype mecanum drive slapped together to get the programmers and drivers practicing!
Unread 07-01-2015, 11:17
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
My team will actually not be using our octocanum, and instead are running mecanum with a very high ground clearance (3+ inches).
Unread 11-01-2015, 01:28
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
What about a 4wd with the rear wheels being traction wheels and the front ones being omnis
Unread 11-01-2015, 01:39
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
4607 has used this in the past - we call it 'Peanut Drive' as that is what our 2013 drive was. I am sure there is another name for it...
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 11-01-2015, 01:46
Team Captain
What were your experiences with it? Did it drive well?
Unread 11-01-2015, 02:01
EricH EricH is online now
Haven't used one myself, but I've seen them in action. They tend to pivot around the traction wheels, rather than the center of the robot as you might expect if you're used to 6WD drop-center, but otherwise they're generally smooth and nimble.
Unread 11-01-2015, 02:13
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
This works well, but as Eric said get used to driving it like a shopping cart. My team did this in 07 and 08 and you're guaranteed not to have a problem turning.
Unread 11-01-2015, 02:24
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
We didn't have any trouble turning, but our belts did tend to slip a lot more than with other drives we've ran. I want to say that has something to do with the non central center of turn. Just a guess though. Otherwise great drivetrain that a driver can good with quickly. I would be suprised if 4607 didn't run it again this year. Although slide is appealing too for reasons already covered in this thread.
Unread 11-01-2015, 11:10
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
We did this drive for 2013. It drove smooth and turned really well. It does have a tendacy to overshoot the turn more though as you have more rotational inertia and very little scrub. We have been considering it again for this year.
Here's a video in action:
http://m.youtube.com/watch?v=QD04NZHPLmc
Unread 11-01-2015, 12:33
lamk lamk is offline
Ken Lam
FRC #4719
lamk is just really nicelamk is just really nicelamk is just really nicelamk is just really nice
We have been driving an off season 6WD square Versachassis with 2 speed gearbox, 4 inches wheel with drop center. Strapped a bunch of totes in various position to the chassis with some clamped on metal bar to see how it drives. The drive team did not like the way how a 6 tote stack lean back and forth. 3 tote stack on the chassis not a big deal.
We remove the center wheel and the turning wasn't too bad and obviously no more leaning back and forth.
We also drove the 4 wheel configuration over the scoring area, bottom out and gouge the brand new built scoring area.
6" traction and omni wheel is on it's way. We will try all omni wheel or 2 omni and 2 traction. We are leaning towards 2 front traction and 2 rear omni but will have to see.
Also one really need to find a way to grab all the totes stacked on your drive train if you wanna move around quickly. We have some really "entertaining" video of "flying totes" when our driver try to turn or accelerate /decelerate too fast. Can't defies the law of physics.
