Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Unread 11-01-2015, 15:16
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: LIDAR Sensor has arrived!
Originally Posted by tech2077 View Post
Right now it seems that only the MXP port is supported with the LIDAR, I'm still investigating, but using the same power source and code, only the MXP I2C port will return data.
Ah, thank you! I originally wrote up my own test code without the scheduler implementation and couldn't get it to work in this port, so I switched to yours with similar results. They seem to work just fine in the expansion port, making me curious if the I2C onboard has a bug or is otherwise disabled on the roboRio. I'll contact NI and let them know.
For now, works perfectly on the MXP, thanks again!
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 11-01-2015, 15:39
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I might get one of these to poke around with. Our programming team is talking crazy talk for autonomous, and I don't know that the drive train will have quite the precision they require to squeak in under 15 seconds.
Anyone tried this out on diamond plate? I bet more than my team has felt a twinge of failure with ultrasonics when moving from the lab to the field.
Unread 11-01-2015, 16:08
tech2077 tech2077 is offline
AKA: Matthew Skolaut
FRC #3847 (Spectrum 3847)
tech2077 is an unknown quantity at this point
Poking around the linux side with i2ctools there are definitive read/write errors showing up for the onboard port, so I'll be sure to let them know.
Anything solid and IR opaque should have good data from this sensor. The diamond plate will definitely give good distance readings, but totes and lexan still need to be tested.
Unread 11-01-2015, 22:33
JesseK's Avatar
FRC #1885 (ILITE)
The raised diamonds on the diamond plate caused excessive backscatter with the sonar sensor. A better way to put the question is, do the diamond shapes cause the Lidar laser to reflect/refract as the robot moves down the wall next to the diamond plate? If so, is it momentary and how long does it take to recover?
Unread 11-01-2015, 23:01
I'll do testing on this as soon as I can, but from what I have tested most surfaces do not refract it enough to actually change the measurements. The only situations I've noticed a problem is with a few thin plastics they are entirely transparent to the IR laser.
Unread 13-01-2015, 11:32
seg9585's Avatar
AKA: Eric
Based on discussion with NI, I'm led to believe the problem may be specific to Java and not the controller itself. NI claims their ADXL345 accelerometer works just fine with I2C when using LabView modules, but I can't get the accelerometer to work with the onboard port either when using Java.
https://decibel.ni.com/content/thread/26778
My FIRST legacy:
Unread 13-01-2015, 11:44
Can you try in C++ as well (either the accelerometer or the LIDAR). Java and C++ share a lot of code, and that might help pinpoint where the issue is.
Unread 16-01-2015, 01:42
Verified to have the same error.
Unread 16-01-2015, 09:57
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
We picked up one of these... it seems very sensitive to glossy/reflective surfaces. Much more so than the lidar system we yanked from a Neato vacuum robot. Not sure what others are seeing. We haven't dived into the sample code yet beyond running it.
Unread 17-01-2015, 16:12
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We have 2 of these and played with them today with LabVIEW. We have been unable to get them to work with the native I2C port on the roborio. However, we have them working just fine on the MXP expansion I2C with identical code. We've pinned them out, swapped the lasers themselves, and still have zero luck with the native port.
The native port DOES know the sensor is connected. We received read and read/write errors stating that the device is busy. This is different that the 'resource not found' error we get when the device is not plugged into to power or not plugged into the I2C.
On the MxP I2C port we are reading then writing in alternating 20 ms loops. We lowered the timing of these loops incrementally until we started getting errors. At 10 ms polling we receive all zeros, at 15 ms we receive data, so 20 ms is where we are (50 hz). We average 5 loops in a moving average filter and the data looks very good.
I know we can improve this by doing the write then checking for the ready bit, but this worked just as well and gave us a resolution we're happy with. Plus after 6 hours of banging our head against the native port we were already pretty frustrated.
We have noticed that when the sensor was aiming at the ceiling and our flourescent lights we got highly inaccurate results.
Unread 20-01-2015, 00:22
Merfoo's Avatar
Merfoo Merfoo is offline
FRC #0955 (CV Robotics)
Merfoo is an unknown quantity at this point
How would one program the LIDAR Sensor for use via DIO in Java?
Unread 20-01-2015, 11:17
marshall's Avatar
I don't know that you can. It's designed to work via PWM output or I2C. The I2C implementation should be pretty similar to the arduino example on their website. The PWM setup will likely just be reading analog input values but don't quote me on that.
Unread 20-01-2015, 11:27
Two possible methods:
  1. Use a low pass filter and read through analog (less programming but requires a resistor and capacitor connected to the output, or
  2. Directly measure the pwm pulse and convert the timing to distance (more programming, but the sensor just drops in and works)
I plan on eventually writing up a pwm based class due to the problems teams have had with this sensor and the onboard i2c port.
Unread 13-01-2015, 10:51
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
What port in Linux are you referring to? What is the dev path you are using?
