Go to Post Just remember, FIRST isn't about the robot, just have fun, meet new people, and try to learn something new. Killing yourself with inhumane amounts of pressure just isn't fun for anyone. - Ian W. [more]
Unread 11-01-2015, 15:52
EmileH's Avatar
EmileH EmileH is online now
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Re: My RoboRio needs a doctor
asnell16,
Have you tried looking at the RoboRIO manual and its LED indicator section?
Confirm your PDP is outputting a proper 6.8-18V output through the CONTROLLER PWR port with a MultiMeter if you get a chance.
Unread 11-01-2015, 15:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
On thing that might help, is to post a couple of clear, large pictures of your electronics setup, so we can see if the wiring is right. It's easy to connect something to the wrong place, without realizing it. I know because I've done it.
If you get some more folks to confirm that it's all wired correctly, you can rule that out.
Unread 12-01-2015, 07:36
Originally Posted by emileh3467 View Post
In order for the RoboRIO to work you do not need to have it wired via CAN. The PDP can function fine without any can interfacing.
The CAN will be used for logging PDP data, hence the robot rule requiring that CAN be connected to the PDP. It is not needed for operation of the RoboRio nor the PDP.
