Go to Post If we miss in autonomous, the team blames the programmer, If we miss in teleop, the team blames the drivers - Jared Russell [more]
Unread 11-01-2015, 15:34
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
[Request] Robot speed rules of thumb
Hello,
I have been in FRC for a while, but for some reason never managed to learn good ball park numbers for reasonable robot speeds.
So let's use the wide open 2014 field as an extreme example, what would constitute a "sane high speed" for 2014?
at the other end of the spectrum, any idea of how to form a "lowest reasonable speed"?
According to the JVN calculator, our numbers for last year were:
  • High speed 14.72 fps (18.17 fps theoretical)
  • Low speed 4.00 fps (4.94 fps theoretical)
I wonder how these numbers fair in comparison to general wisdom about advisable speeds.
Right now we are shooting for ~11 fps for 2015, but i'm now thinking we might want to aim for a lower speed for increased precision.
Thanks for the help!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 11-01-2015, 15:50
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: [Request] Robot speed rules of thumb
Rules of thumb will differ from team to team, but here is what I have used:
7 ft/s Slow
10 ft/s average
13 ft/s Fast
>16 ft/s Might be too fast to control
As for "precision" of a drive train.
Many things other than speed really effects this. If you build a stiff, tight and low friction drive train you will have very similar precision positioning ability at many speeds. Also programming an exponential throttle response can help the driver with low speed interactions. Trouble can be had when the skid friction needed to turn is high. This can cause the driver to have less control of the exact position during turning
For this year, I'd suggest you just build a robot with very little skid friction.
Just remember that top speed isn't really whats important. It's the point-to-point time for a robot that is important.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 11-01-2015, 17:00
DonRotolo's Avatar
Back to humble
FRC #0832
I essentially agree with Jeff, however I think slow is a little bit slower, and fast could be a little faster. I do agree 16+ fps is a challenge to control, but you absolutely must factor in how well your drivetrain is put together, since a good one is easier to drive. The quality of your driver, and the practice time they get, is perhaps the most important factor.
Unread 11-01-2015, 18:25
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Speed is an interesting factor this year considering per rules given there is no reason why a robot without a drive base couldn't score. If you are using these "rules" to determine what speed your robot should go I would suggest you consider otherwise because speed (in my mind) isn't a really important factor this year.
I'll try to make this simple but its hard for me to explain its just something that I observed nobody taught me this so I couldn't dig up a lesson plan.
In this kind of game "speed" isn't as important of a measurement as "idle time" you want all mechanisms working together to make sure your robot is always performing an action that would contribute to scoring. Wasted time is wasted scoring potential in that regards getting to a point on the field quickly isn't as ideal as getting to a point on the field when you are ready. If you zoom over to where you need to be but you aren't quite ready to off load a stack I would refer to the time spent fidgeting as "idle time". What sucks about "idle time" is that time isn't enough to increase your scoring potential. Its enough time that you lose scoring potential but not enough time that you can do anything meaningful to make up for it. The speed of your robot and the mechanisms on it need to work together to minimize this sort of idle time.
Hope that makes sense! If not I'll try and rephrase it as a Haiku...
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
So I got my jacket back, but it turns out the "W" in WPI doesn't stand for that steak sauce I can't pronounce.
Play is for kids this is serious...
Unread 11-01-2015, 19:54
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
The "right" speed is difficult to provide a universal answer for. In general, if your robot is an offensive based robot, it needs to be faster. The right speed should be fast enough that you're able to control both the robot as well as any field elements. We've traditionally had a top speed around 15 fps. For ultimate ascent we had a top speed of 12 fps with increased control. While the better control was nice, we were limited to two runs whereas the faster robots were getting three in. Last year, we had a top speed up around 18 fps and we routinely lost control of the ball because we were so fast in driving so we actually drove at speeds that were less than optimal.
For the low end, that's key for defense or for high control/high torque scenarios, such as the bridges in Rebound Rumble. I don't see the need for a low gear this year. For those defensive push matches 4 to 6 fps should be sufficient.
I agree that this year will be about deliberate control and effective pacing more than incredible speed. That said, the robots that will be top seeds at St Louis will be incredibly fast but they also don't need this blog for inputs. We all tend to follow their lead.
Scott McLean
FIRST Team 3512, the Spartatroniks
Team role: mentor
2011: Highest Rookie Seed and Rookie Inspiration Award Long Beach Competition
2012: Winner Los Angeles Regional -- w/ Team 987 and Team 1717
2013: Finalist Los Angeles Regional -- w/ Team 599 and Team 981; Engineering Excellence
2015: Entrepreneurship Award - Ventura Regional
