Go to Post Just wear your safety glasses. They can be stylish, too! - Eugenia Gabrielov [more]
Unread 01-08-2015, 11:53 PM
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Re: LIDAR Sensor has arrived!
From the products google groups
https://groups.google.com/forum/#!to...3d/ebRaHl6sylM
Paul,
That's very exciting... in the course of looking at the forum I found Innovation First International... I grew up fairly near Greenville, TX. Will be joining the forum to follow along... have been getting into ROS.org and robotics in my hobby-time.
@Polycarbonate - the way the sensor acquires readings is by sending a bunch of pulses out and then capturing what comes back, combining those into a "correlation record" and then measuring the distance between the crossing point in the reference signal and the next strongest signal (or if you ask for it, the second strongest).
There are a few surfaces and conditions it can't "see" but in my experimental experience it can detect most surfaces from one angle or another. Sometimes with reflective and clear surfaces you can get unexpected results, but that's where that second reference comes in handy. You can use it to see a reflection or an object on the far side of a clear object if you are picking up your strongest signal from the clear object.
Pg. 17 "Signal Acquisition process" through pg 22 "Processing" of our manual goes into detail about how the sensor records information: http://pulsedlight3d.com/pages/docs
Let me know if you have any more questions very happy to help! We're excited about what the chiefdelphi.com community is going to do with LIDAR-Lite!
- Austin
Unread 01-10-2015, 10:06 PM
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Originally Posted by tech2077 View Post
In case anyone is interested, I wrote up a java class for this, you can use the start/stop functions to use the built in updater Timer, or use the update function to only poll distance when needed.
LIDAR.java
tech2077, are you having any luck with this code? When I attempt to run I get zero distance data. Also, the i2c.read() function returned "true" (aborted). I'm passing in Port.kOnBoard and the sensor is plugged into the I2C port on the roboRio
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 01-11-2015, 03:33 AM
tech2077 tech2077 is offline
AKA: Matthew Skolaut
FRC #3847 (Spectrum 3847)
tech2077 is an unknown quantity at this point
Strange, it has worked for me. I've been using the mxp port so far, so I'll test with the on board one.
Unread 01-11-2015, 04:16 AM
Right now it seems that only the MXP port is supported with the LIDAR, I'm still investigating, but using the same power source and code, only the MXP I2C port will return data.
Unread 01-11-2015, 10:20 AM
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to behold
Dimensions: 21 X 48.3 X 35.5 mm
• Performance: Range: 0-40m Laser Emitter
• Accuracy: +/- 0.025m
• Power: 5vdc, <100ma
• Acquisition Time: < 0.02 sec
• Rep Rate: 1-100Hz
• Interface: I2C or PWM
•Max Operating Temp.: 70° C
•Eye safe, laser hazard free
Works up to 40 m, + or - 2.5 cm, <20 ms acquisition time.
We have ordered one.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
Unread 01-11-2015, 03:16 PM
seg9585's Avatar
AKA: Eric
Ah, thank you! I originally wrote up my own test code without the scheduler implementation and couldn't get it to work in this port, so I switched to yours with similar results. They seem to work just fine in the expansion port, making me curious if the I2C onboard has a bug or is otherwise disabled on the roboRio. I'll contact NI and let them know.
For now, works perfectly on the MXP, thanks again!
My FIRST legacy:
Unread 01-11-2015, 03:39 PM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I might get one of these to poke around with. Our programming team is talking crazy talk for autonomous, and I don't know that the drive train will have quite the precision they require to squeak in under 15 seconds.
Anyone tried this out on diamond plate? I bet more than my team has felt a twinge of failure with ultrasonics when moving from the lab to the field.
Unread 01-11-2015, 04:08 PM
Poking around the linux side with i2ctools there are definitive read/write errors showing up for the onboard port, so I'll be sure to let them know.
Anything solid and IR opaque should have good data from this sensor. The diamond plate will definitely give good distance readings, but totes and lexan still need to be tested.
Unread 01-11-2015, 06:34 PM
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
LIDAR.java
How do you (or anyone that has gotten this to work) implement this with the main class. I specifically am using the "Getting Started" example.
I tried using it something like this (don't have the exact code in front of me...):
Where variables are declared:
LIDAR myLidar = new LIDAR(port.kOnboard);
then in teleopPeriodic() I did:
myLidar.update();
System.out.println(myLidar.getPID());
However, 0.0 is only ever printed out to the Riolog. (I also tried having the myLidar.start() and myLidar.stop() inside of teleopInit and disabledInit respectively.
Thanks in advance,
DavisC
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 01-11-2015, 08:23 PM
myLidar.update();
Thanks in advance,
DavisC
It's been discovered that the on board I2C port is having communication problems, use the I2C on the MXP port until the issue is resolved.
Unread 01-11-2015, 09:39 PM
FRC #0539 (Titans)
Angry Re: LIDAR Sensor has arrived!
Thanks, so I just use kMXP instead of kOnBoard and connect to the expansion port bottom left 2 pins for sda and scl?
FRC Team 539
Unread 01-11-2015, 09:45 PM
seg9585's Avatar
AKA: Eric
Correct. I still had my sensor power pins plugged into the I2C power and ground ports, which seem to work (for what it's worth).
Also, if you execute myLidar.start(); in your init area or constructor, you can access myLidar.getDistance() in both autonomous and teleOp methods and allow it to run its own thread, which will help avoid bogging down the rest of your code (because the update() method includes delay timers up to ~10ms to write and read).
My FIRST legacy:
Unread 01-11-2015, 10:33 PM
JesseK's Avatar
FRC #1885 (ILITE)
The raised diamonds on the diamond plate caused excessive backscatter with the sonar sensor. A better way to put the question is, do the diamond shapes cause the Lidar laser to reflect/refract as the robot moves down the wall next to the diamond plate? If so, is it momentary and how long does it take to recover?
Unread 01-11-2015, 11:01 PM
I'll do testing on this as soon as I can, but from what I have tested most surfaces do not refract it enough to actually change the measurements. The only situations I've noticed a problem is with a few thin plastics they are entirely transparent to the IR laser.
Unread 01-12-2015, 08:45 PM
WDB WDB is offline
FRC #2363
WDB is an unknown quantity at this point
We tried the I2C port too and failed. Moved over to the MXP and still getting zeroes.
Using lidar.start() in the teleopInit and calling lidar.getDistance() in teleopPeriodic which is returning zero. Am I missing anything?
Thanks!
