Go to Post PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. - dlavery [more]
Unread 11-01-2015, 19:54
Munchskull's Avatar
Munchskull Munchskull is online now
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Disk brakes
My team is planning on using a disk brake on our elevator system. We have standardized on 1/2 in hex stock for any type of shaft. The problem is that i can not find any disk brakes that use 1/2 in hex. How have other teams used disk brakes in the past?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 11-01-2015, 20:00
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Disk brakes
We used a disc brake last year on our shooter.
No you won't find them in hex profiles.
We made our own aluminum disc last year that doubled as the spool for our cable/winch assembly. You can make your own disc and bolt it to a versa hub.
1058 PVC Pirates 2016 - xxxx
Unread 11-01-2015, 20:11
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Re: Disk brakes
An aluminum plate sprocket on a Versa-hub would do for a rotor in a pinch.
Unread 11-01-2015, 20:17
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
Re: Disk brakes
Funny, I have been having a hard time finding bike wheels with 1/2" hex too...
The sprocket idea has to be the most cots friendly solution.
2005-2006,2011 FRC 865 Warp7 Student, Mechanical team
2013 FRC 1310 RUNNYMEDE ROBOTICS Mentor, CAD and Manufacturing
2014-2015 FRC 5031 Downsview Robotics Mentor, Design and Manufacturing
2016-Present FRC 1360 Orbit Community Robotics Mentor, Design and Manufacturing
Unread 11-01-2015, 20:41
Munchskull's Avatar
Team Role: CAD
Re: Disk brakes
That is actually a great idea. They fit the profile perfectly.
They sure would be better than what we can cnc plasma.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 11-01-2015, 20:45
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: Disk brakes
I know that 948 had an arm with brakes on it. This was a while ago though, maybe 2005. I think they did something based on bicycle brakes.
Unread 11-01-2015, 21:18
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: Disk brakes
We did this on our shooter last year and it worked great, just don't paint the sprocket without masking the rotor area.
Unread 11-01-2015, 22:14
Munchskull's Avatar
Team Role: CAD
Re: Disk brakes
That is what we are planning to do. Use a disk brake caliper from a bike and now a plate sprocket to keep our elevator stationary.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 11-01-2015, 22:46
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Disk brakes
Here are a couple of views of how we used a disk brake for our 2011 winch controlling the should joint of the our scoring arm. We used brake cable and short stroke pneumatic to actuate it. It is all mounted on an AndyMark toughbox.
ID:	17814  Click image for larger version
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
