Go to Post Don't trust everything you read on Chief Delphi. - Peter Matteson [more]
Unread 11-01-2015, 14:47
vps vps is offline
FRC #3021 (The Agency)
vps is an unknown quantity at this point
Problem calling START_ROBOT_CLASS(_CLASSNAME_) Wrapper
I'm having trouble calling my wrapper - it hasn't happened before. Here's the code that has been reduced to purely illustrate the problem.
//Atlas.h
#include "WPILib.h"
class Atlas: public SampleRobot {
	Gyro* gyro;				//just some filler here
public:
	Atlas();
	~Atlas();
	void Autonomous();
	void OperatorControl();
	void Test();
//Atlas.cpp
#include "Atlas.h"
Atlas::Atlas() {
	gyro = new Gyro(1);
Atlas::~Atlas() {
	delete gyro;
void Atlas::Autonomous() { }
void Atlas::OperatorControl() { }
void Atlas::Test() { }
//initialize.cpp
#include "Atlas.h"
START_ROBOT_CLASS(Atlas);    //error here
The error is:
Invalid arguments '
Candidates are:
? HALReport(?, ?, ?, const char *)
help?
Unread 11-01-2015, 15:02
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: Problem calling START_ROBOT_CLASS(_CLASSNAME_) Wrapper
What happens if you try to deploy it? I believe that's an error with the internal eclipse compiler, and your code will actually compile.
Unread 11-01-2015, 15:03
vps vps is offline
Note how the problem persists when everything is consolidated in one file:
//Atlas.cpp
#include "WPILib.h"
public:
	Atlas() {
		gyro = new Gyro(1);
	~Atlas() {
		delete gyro;
	void Autonomous() { };
	void OperatorControl() { };
	void Test() { };
START_ROBOT_CLASS(Atlas);         //same error here
Unread 11-01-2015, 15:05
vps vps is offline
I have not tried to deploy this since it cannot even properly build. Right now, I'm at home so I cannot try that. Any other suggestions?
Unread 11-01-2015, 15:20
WPILib Developer
FRC #0190
What I'm saying is that the internal eclipse builder thinks that's an error, but it's not. It should deploy properly when you connect to the roboRIO.
Unread 11-01-2015, 19:38
vps vps is offline
Thanks. I'll try it out on Monday. Has this happened to you before?
Unread 11-01-2015, 20:32
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
We've experienced this issue multiple times. You should be fine if you compile. If it's bugging you just delete the error from the console window and it should go away.
Unread 11-01-2015, 20:40
mega900997's Avatar
mega900997 mega900997 is offline
FRC #0263 (Sachem Aftershock)
mega900997 is on a distinguished road
If you know you coded it right and its just the compiler saying you have an error, re-index it by right clicking on the project, scroll down to the index option and select rebuild. You'll only have the standard gcc and etc errors.
Suffield Shakedown Winners & Most Points Scored
South Florida Regional 6th Seed, #5 Alliance Captains, Regional Winners w/ 2383 & 386, Innovation in Control Award
NY Tech Valley Regional 5th Seed, QF, Excellence in Engineering Award
SBPLI Long Island Regional 4th Seed, Finalists
Hopper Division 14th Seed, QF
Unread 11-01-2015, 22:50
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
x2
