Go to Post ...and then at the end they interviewed this 5 year old on his favorite part (of the fair): "I liked the robot" - Jessica Boucher [more]
Unread 11-01-2015, 20:57
btcshields6 btcshields6 is offline
FRC #4206
btcshields6 is an unknown quantity at this point
Re: Adjusting Compressor Settings
So, in essence, I'm not able to change either end?
Thanks anyway.
Unread 11-01-2015, 21:14
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
Yes, that's correct. The sensor has 2 states - true and false. They cannot be adjusted.
Unread 11-01-2015, 21:18
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
But you can replace it with one that is properly calibrated.
Unread 11-01-2015, 21:57
FRC #4206
Well, I looked into that, but unfortunately R68 in the Robot Rules prohibits using any other pressure switch besides the Nason pressure switch, P/N SM-2B-115R/443.
Unread 11-01-2015, 22:16
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
The 115R in the part number means it should switch off at 115 PSI rising. If yours is switching off at 90 PSI rising, then it is out of spec. If it is new, it should be returned to be fixed. The other possibllility is your pressure gauge is reading low and the switch is working correctly.
Unread 11-01-2015, 23:03
FRC #4206
Hmm. That could be the root of this entire problem. I'll switch out our gauge tomorrow and see if that solves the issue. Thanks!
