Go to Post Really, flight? That is going to feed the rumor mill... - Munchskull [more]
Unread 11-01-2015, 13:44
Twins Inc.'s Avatar
Twins Inc. Twins Inc. is offline
wait....are you a twin??
AKA: Zach Larson
FRC #2605 (Sehome Seamonsters)
Twins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really nice
pic: 2605 Mecanum Drive
Unread 11-01-2015, 13:46
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Re: pic: 2605 Mecanum Drive
Do you have something keeping the belts tensioned apart from the screws to tighten the cim down. If it doesn't I think it will gradually get loose and the belts might fall off. What I'm thinking of is something like the WCP cam tensioner.
Unread 11-01-2015, 14:27
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Really love the simplicity of this, and it's a perfect use for your encoder mounts.
What's the overall reduction, and what size wheels are those?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 11-01-2015, 14:37
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
We've done chain drivetrains like this and found that they slip unless you use something like star washers on the bolts. This was sixteenth inch sheet metal though, these tubes might work better.
Unread 11-01-2015, 14:41
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
+1 on the slippage issue. That was our primary problem last year. Add a WCP cam or something to keep it tensioned or it will slip.
Unread 11-01-2015, 17:04
Twins Inc.'s Avatar
AKA: Zach Larson
I believe the reduction is 9:1, and those are 6 inch AndyMark Wheels (not HD). We'll be cutting a smaller reduction soon, because these gears actually pinch the belts on the ground and cause problems.
Thanks for the input! We'll look into adding a cam next to each motor.
Unread 11-01-2015, 17:31
Originally Posted by Twins Inc. View Post
I believe the reduction is 9:1, and those are 6 inch AndyMark Wheels (not HD). We'll be cutting a smaller reduction soon...
At 9:1 with 6" wheels the bot free speed is already on the high side for this year's game, no?
Unread 11-01-2015, 19:44
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
We had the exact same gearing and wheel size last year, and it was only a moderate speed on the field.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 11-01-2015, 19:54
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Am I the only one a little worried about the side load you're putting on those CIMs? Direct belt drive off a CIM just doesn't seem like a great idea, even if they're super robust
Unread 11-01-2015, 21:44
9:1 on a 6 inch wheel is 15.4 fps free speed. Twins Inc indicated they're going to gear it even faster. Some would say that's a bit too fast for this year's game. How fast do you plan to gear your bot this year?
Unread 11-01-2015, 22:39
holygrail's Avatar
holygrail holygrail is offline
Gavin Wood
FRC #1939 (The Kuhnigits)
holygrail is just really niceholygrail is just really niceholygrail is just really niceholygrail is just really nice
We usually gear for around a 15 to 17 fps free speed but then we use code to tone it down a bit so that when you push the joystick forward you only get 50 to 70% of the full speed. We have a turbo button on the joystick that the driver has to push for full speed. Works well.
Unread 11-01-2015, 23:07
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
With mecanums it's not a bad idea to gear a bit on the fast side anyways. Even though your wheels are spinning at a particular speed, doesn't mean your robot will move at the same speed - especially if your mecanum rollers don't have a lot of friction, which is ideal for moving sideways.
It's one of the strangest things to see a mecanum drivetrain drive, and watch the wheels spin faster than the robot is travelling...
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 11-01-2015, 23:09
Physics Quiz:
Imagine you have 2 robots which are identical in every way, except that Robot A is geared for 8 fps, and Robot B is geared for 16fps but has the voltage limited to 50%.
Describe the performance differences between the 2 robots: acceleration, motor heating, battery drainage, pushing force, fine control of slow maneuvers, etc.
Unread 11-01-2015, 23:15
Originally Posted by Mr. Lim View Post
It's one of the strangest things to see a mecanum drivetrain drive straight forward, and watch the wheels spin faster than the robot is travelling
Do you have a video you could post.
Unread 11-01-2015, 23:21
Twins Inc.'s Avatar
AKA: Zach Larson
Physics Quiz:
I imagine that the bot with the higher gear ratio, bot A, (or lower fps) would have more control and less acceleration than B. But also more heating, and power consumption because of more motor use/rpm. Or am I mixing things?
