Go to Post Yes, the real world is like that. Let's operate on a higher plane. - Taylor [more]
Unread 11-01-2015, 23:14
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
How to use 6" wheels with AM14U2
So our team wants to use a modified version of the kit chassis with 4 wheels (2 traction on the front, 2 omni on the back). The wheels in question are 6" and to put the axles through the middle mounting holes on the chassis instead of the farthest out ones. We did some measurements for 42 teeth 5mm HTD pulleys and found that the two closest available belt sizes for the hole spacing (about 18.5") were 225T which space 18" apart and 250T which space 20.5" apart.
Is it reasonable to tension out 2" on the top and bottom(potentially using some funky shapes) or should we try something else, like putting a dead pulley in the middle that they both attach to.
We wan't to avoid using chain if possible.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 11-01-2015, 23:29
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Re: How to use 6" wheels with AM14U2
We are using 160 tooth belts for 4wd long with 6 in wheels.
http://files.andymark.com/Graphics/locations.jpg
Unread 11-01-2015, 23:40
JohnFogarty's Avatar
AKA: @doctorfogarty
Our team is doing the same as listed above. That file is really useful.
John Fogarty
Unread 11-01-2015, 23:42
Chris is me's Avatar
AKA: Pinecone
It's reasonable to tension a belt that is just a bit too big for the application. You could probably use a delrin sleeve, with a slip fit bore over a bolt as a tensioner. Start with a big sleeve, turn it down on a lathe until it feels like a "just right" size, set it and forget it. Once you get the tension right you're good to go all year.
Unread 12-01-2015, 01:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We just notched the end rails, so they would clear the 6 inch wheels using the longer belts. This increases our robot's wheelbase by two inches, compared to getting the 160 belts, which helps to increase robot stability. it kept a couple students busy for an hour or two. No problems so far.
