Go to Post Oh yes - and thanks for giving us kids our dreams. - DonRotolo [more]
Unread 11-01-2015, 20:43
Hsifeulbhsifder Hsifeulbhsifder is offline
Programmer
AKA: Zaeem Mohamed
FRC #5428 (Breaking Bots)
Rookie Year: 2015
Hsifeulbhsifder is on a distinguished road
Regarding flashing the roboRIO
Is there any way to send code to the roboRIO from the command line, so custom build scripts can be created?
Unread 12-01-2015, 00:59
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: Regarding flashing the roboRIO
Sure, take a look at the ant scripts in the ~/wpilib/{java, cpp}/current/ant directories. The roboRIO supports SSH, username admin with a blank password.
Unread 12-01-2015, 02:50
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Note that you want to upload code as lvuser, not admin, to avoid permission problems. If you are switching between languages, you will also want to update the /home/lvuser/robotCommand script as appropriate.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 12-01-2015, 09:57
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Yup, what Peter said (we got bit by this problem). Do not use the admin user. You will cry.
The ant scripts are a bit difficult to read. If you want an example in an actual programming language (python), check out https://github.com/robotpy/pyfrc/blo.../cli_deploy.py (obviously we're uploading different artifacts, so take that into consideration).
Unread 12-01-2015, 19:15
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
Thanks, I was actually creating an interpreter that could run code directly on the roboRIO. I will look into the pyfrc code.
