Go to Post I have to remind myself you guys are from Kansas when I hear the country music...I'm not even sure any Texas Teams do that ;) - JohnSchneider [more]
Unread 12-01-2015, 02:50
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: Regarding flashing the roboRIO
Originally Posted by fsilberberg View Post
Sure, take a look at the ant scripts in the ~/wpilib/{java, cpp}/current/ant directories. The roboRIO supports SSH, username admin with a blank password.
Note that you want to upload code as lvuser, not admin, to avoid permission problems. If you are switching between languages, you will also want to update the /home/lvuser/robotCommand script as appropriate.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
