#16
Re: My RoboRio needs a doctor
asnell16,
Have you tried looking at the RoboRIO manual and its LED indicator section? Confirm your PDP is outputting a proper 6.8-18V output through the CONTROLLER PWR port with a MultiMeter if you get a chance. ![]() ![]() ![]() ![]() Last edited by EmileH : 11-01-2015 at 15:54. |
#17
On thing that might help, is to post a couple of clear, large pictures of your electronics setup, so we can see if the wiring is right. It's easy to connect something to the wrong place, without realizing it. I know because I've done it.
If you get some more folks to confirm that it's all wired correctly, you can rule that out. |
#18
The CAN will be used for logging PDP data, hence the robot rule requiring that CAN be connected to the PDP. It is not needed for operation of the RoboRio nor the PDP.
