Go to Post Be realistic in your goals, and relentless in hitting them. - IKE [more]
Unread 05-01-2015, 20:51
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
pic: 3 Tier Stack?
Unread 05-01-2015, 20:52
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Re: pic: 3 Tier Stack?
I hope to see the Cheezy Poofs pulling this off with a wooden robot.
Unread 05-01-2015, 21:44
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Would this put the tote up another level because it is simply based off of height, not the number of totes?
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 05-01-2015, 22:08
Nope, not the tote. 6 tote points.
However, the Recycler up there could potentially be in Level 4. No backstop there, so I can't tell for sure.
Unread 06-01-2015, 10:19
AKA: Cam Pizzo
Doh! Still getting used to lingo for this year. I did mean the recycle bin, thank you.
Unread 06-01-2015, 14:39
Rypsnort's Avatar
Rypsnort Rypsnort is offline
AKA: Ian Rypkema
FRC #0706
Rypsnort will become famous soon enough
I feel that this would be very difficult to do with a robot.
Alumni:
2016 Finalist-Buckeye
Team Member:
2015 Creativity Award - Queen City
2015 Quality Award - Wisconsin
2014 Finalist-Lake Superior
2014 Industrial Design-Lake Superior
2014 Finalist-Wisconsin
2014-Quality-Wisconsin
2013-Finalist-Buckeye
Go ZAGs
Unread 06-01-2015, 14:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This made me think of an interesting question.
Will tall tote stacks (regardless of orientation) be impacted by high speed robots crossing the white bump? It would be cool to have the Cheesy Poofs, Robonauts or other team which plans to build a field to scale with FRC carpet do some experiments.
Unread 06-01-2015, 16:09
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The field drawings spec the scoring areas as a sheet of 1/2" plywood on top 3 strips of (3/4" plywood + 1/2" plywood). That whole plywood platform gets stuck to the carpet with 2 long strips of 2" velcro. The HPDE gets velcroed to the top of the 1/2" sheet and the ramps are velcroed to a short bevel on the edge of the sheet. It looks like the bottom edge of the ramps isn't velcroed to the carpet. The ramps are definitely only supported by the carpet at the bottom and the velcro/plywood at the top.
Anyways, the 2 strips of velcro will probably provide enough grip that the only way you're really moving things is if you move the carpet. I'd be more worried about how the 1/4" thick HDPE ramp is going to react if you hit it at high speed. It's a 7" long span only pinned at the ends, so if you hit it fast enough, you'll probably deflect it a bit, which might make the ride over the bump a little rougher than at slower speeds.
Unread 06-01-2015, 21:34
samfruth's Avatar
Team Role: Driver
We ended up measuring the lowest position of the recycling bin on the top tote and found it to be 50 in. After mathing, this would put it in the fourth zone, therefore optimizing the usage of three totes.
Unread 08-01-2015, 08:20
DoughBoy's Avatar
DoughBoy DoughBoy is offline
FRC #3336 (Zimanators)
Team Role: Tactician
DoughBoy can only hope to improve
You cant score any points the way he has it set up since the orientation has to be the same as the other totes.
Unread 08-01-2015, 08:33
ATannahill ATannahill is offline
AKA: Alex Tannahill
I don't remember ever reading or hearing anything like that. Can you tell me where that is in the manual?
Unread 12-01-2015, 08:46
greasemonkey's Avatar
greasemonkey greasemonkey is offline
Truss me I'm a Doctor
AKA: Fred Parker, fredword, fredwardo, phred, frederick
FRC #3467 (windham windups)
greasemonkey is an unknown quantity at this point
Its legal
Duct tape, a hammer and a lot of prayers
