Go to Post But as with all things: we shall see. - pfreivald [more]
Unread 12-01-2015, 09:56
igorjavaroni igorjavaroni is offline
FRC #1382 (ETEP Team)
igorjavaroni is an unknown quantity at this point
The last update firmware RoboRio?
Hey huys, i'm with problems with the last update firmware of roborio, i have 3 firmwares files:
1 - roboRIO_2.1.0f0.cfg - 29/07/2014
2 - roboRIO_2.1.0f3.cfg - 16/12/2014
3 - roboRIO_2.2.0f0.cfg - 23/10/2014
Wich one is the last update firmware?
Unread 12-01-2015, 10:18
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: The last update firmware RoboRio?
The latest date is 16/12/14 which if you americanize it is Dec 16 2014. I see you are in Brazil which explains date.
The one in the manual is image FRC_2015_v23 and firmware 2.1.0f3.
Unread 12-01-2015, 10:23
Go with Franks recommendation and use the latest:
