Go to Post FIRST like life is what you make of it, if you would rather go through FIRST worrying about what other teams do to make their robots, then your destined for disappointment. if you go through FIRST making the most of it doing the best you and your team can then it doesn't matter what other teams do. - Mike Schroeder [more]
Unread 12-01-2015, 09:40
tdbroun tdbroun is offline
AKA: Tim Brounscheidel
FRC #1507 (Warlocks)
tdbroun is an unknown quantity at this point
Anyone used a roborio usb port for a flash drive?
Our team is thinking of writing log files to a flash drive on the roborio so that we can access them in the pits when there are 3 mechanical guys climbing all over the robot (so we can't power it up and copy the files off).
When we drop a flash drive in, nothing happens. I'm no linux ace, but I assume I need to load a driver and mount the device on the filesystem.
Has anyone had success with this?
Unread 12-01-2015, 11:54
Re: Anyone used a roborio usb port for a flash drive?
It will be mounted to /media/sda1 with a symlink to /U. See the roboRIO user manual https://decibel.ni.com/content/docs/DOC-30419
Unread 12-01-2015, 19:06
Thank you very much. Works like a charm. I was expecting it under /mnt
