Go to Post Don't be in a rush to build a robot until you know what robot it is you need to build. - Chris Fultz [more]
Unread 09-01-2015, 20:24
denaliman99 denaliman99 is offline
FRC #0240
denaliman99 is an unknown quantity at this point
roboRIO usb
Does anyone know if you can use a usb hub on the roboRIO to increase the number of available usb ports to support additional cameras, etc.?
Unread 09-01-2015, 20:33
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: roboRIO usb
Hubs are part of the USB standard, so I don't see any reason why you wouldn't be able to use a USB hub. (I wouldn't be surprised if the 2 USB ports were 1 port connected like a hub internally.)
That said, make sure you either use a powered hub or make sure all the devices connected to the hub draw >900 mA/4.5 W total, the maximum current per port according to the roboRIO specifications.
Unread 10-01-2015, 17:54
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: roboRIO usb
We've done it. It works fine as long as you don't try to pull too much current from the RoboRIO. 500ma is the max draw on USB 2.0. So, if you're trying to power 3 cameras, for example, you'll likely be in an overcurrent situation. Try powering the hub from a 5V supply and see if it works better for you.
HTH,
Mike
Unread 10-01-2015, 18:01
cgmv123's Avatar
AKA: Max Vrany
Re: roboRIO usb
The roboRIO specifications document says the maximum draw per port is 900 mA.
Unread 10-01-2015, 18:52
Software Mentor
AKA: Mike Anderson
Re: roboRIO usb
Quite true. That is the number they list. However, that *is* in excess of the USB 2.0 spec. That number is in line with the USB 3.0 spec, but the port on the RoboRIO isn't listed as a USB 3.x device. So, yes, you *should* be able to get by with it. But, even though the RoboRIO can supply 900ma, it doesn't mean that your hub is built to handle that kind of current inbound from a single USB port. You'd still be better off with a powered hub, IMHO.
Good luck,
Mike
Unread 10-01-2015, 20:36
cgmv123's Avatar
AKA: Max Vrany
Re: roboRIO usb
Agreed.
Unread 12-01-2015, 12:08
Merfoo's Avatar
Merfoo Merfoo is offline
FRC #0955 (CV Robotics)
Merfoo is an unknown quantity at this point
Re: roboRIO usb
Hello I'm trying to use a usb hub on the roborio to increase the amount of usb cameras we can use as well, the problem I'm having is that I can't get the images from the camera when it is plugged into the usb hub. I have tried two usb hubs, one that was powered from 5v and one that was not. The camera shows up on the roborio web interface when plugged into the usb hub that is NOT powered by a 5v but I'm still not able to get images from it in java. You guys have any ideas what could be happening? (Sorry if I threadjacked)
Unread 12-01-2015, 12:40
Re: roboRIO usb
Have you changed the camera address in your java program to match the address reported in the web dashboard?
Unread 12-01-2015, 13:49
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: roboRIO usb
900mA is indeed from USB 3.0 as roboRIO is designed to support USB 3.0 bus powered cameras, though at USB 2.0 rates.
Unread 12-01-2015, 15:05
Merfoo's Avatar
Re: roboRIO usb
By address do you mean the name, ex "cam0"? If so the name didn't change when plugged into the usb hub.
Unread 13-01-2015, 06:49
Re: roboRIO usb
As a point of compare, you may try launching Vision Assistant and choosing to Acquire images. You can pick the USB camera such as "cam0" in the list and see if it works there.
Greg McKaskle
