Go to Post However, because they're programmers they just redid the interpolation tables for our motors as opposed to actually fixing the bent shooter. - Nuwanda [more]
Unread 12-01-2015, 16:24
frc_rules frc_rules is offline
frc_rules is an unknown quantity at this point
Has anyone tried/managed to get 2015 java code to run on last year's cRIO for FRC?
The title says it all. The 2015 update pack still has the imaging tool for the cRIO and I successfully updated it. Not sure where to go from there.
Unread 12-01-2015, 16:30
Ben Wolsieffer Ben Wolsieffer is online now
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Has anyone tried/managed to get 2015 java code to run on last year's cRIO for FR
The roboRIO runs Linux and Java SE Embedded, both of which cannot run on the cRIO (well they *possibly* could, but I wouldn't recommend trying it). The Java VM on the cRIO only runs a very limited version of Java 3.
Unread 13-01-2015, 13:45
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
If you are wanting to program the cRIO with Java you will need to grab a copy of Netbeans and the 2014 FRC Java Plugins. As lopsided98 pointed out, the setup for programming the roboRIO with Java is quite different and will not work on the cRIO.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 13-01-2015, 14:18
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I would put the 2014 image back on it for Java. The 4 slot CRIOs can be programed in the new Labview & I expect that is what the 2015 update is for.
