Go to Post We need to celebrate great things because good enough isn't inspiring. - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 09-01-2015, 21:21
nstephenh nstephenh is offline
FRC #0900
nstephenh is on a distinguished road
LIDAR Sensor with a motor in it
Hello, I'm a programmer from team 900. Recently we aquired a 2-dimensional LIDAR sensor from a used Neato XV-11. This sensor has a small motor built into it, making the sensor spin. As the only COTS parts with motors in them can be hard drives and fans, this is not a legal part, as clarified by FIRST when we asked here: https://frc-qa.usfirst.org/Question/...tor-ex-a-pan-t
We however, feel that although this ruling is by the rules verbatim, it is not in the spirit of the rule. The motor is an integrated part of a self contained sensor module, and does not have any mechanical effect on the surrounding components. We are not trying to get FIRST to revoke their ruling, but we are curious if any other teams are looking at using these. Any thoughts?
Unread 09-01-2015, 21:56
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Re: LIDAR Sensor with a motor in it
Is the laser a class 1 laser? Not a class 1m but a class 1.
Unread 09-01-2015, 21:59
lonnie lascelle's Avatar
lonnie lascelle lonnie lascelle is offline
Team Mentor
FRC #0930 (Mukwonago BEARs)
lonnie lascelle is on a distinguished road
Just curious.... I think the kinects have motors. If so, would that make it illegal?
Unread 09-01-2015, 23:06
FRC #0900
Yes, it is a class 1.
We will ask in the Q&A.
Unread 12-01-2015, 15:16
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
The Q&A clears this up https://frc-qa.usfirst.org/Question/...bots-this-year
Unread 12-01-2015, 15:24
FRC #0900
Originally Posted by nickmcski View Post
Yep, our team was the one who asked. Was just coming online to post it, but you beat me to it.
Unread 12-01-2015, 15:56
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
I will add that what they have said is that sensors using Servos need to have their servos plugged into the RoboRIO (or I'm assuming any approved MXP modules). The kinect does not utilize a servo... it is a motor, just to be clear. Here's a picture of said motor:
https://d3nevzfk7ii3be.cloudfront.ne...3WOfFkelK.huge
I'm left with more questions after the ruling. Does it mean that the kinect can be used with its motor if the motor is powered via a PWM port on the RoboRIO? What constitutes a servo? Can any 5v motor be used as a servo? Do the Q&A folks read Chief Delphi and know about this thread? SOOO many questions!
Unread 12-01-2015, 16:44
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Based on the Q & A response I would remove the motor (or the whole base) and you are good. It is too bad they didn't whitelist the Kinect since it was a KOP device.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 12-01-2015, 17:10
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
So based on the Q&A you will not find out until inspection. If what is in the Kinect is a "motor" not listed in the rules, you will have to replace it one listed in the rules (window motor )& control it from the RoboRIO. You are better off calling it a "servo". Hopefully the GDC rethinks this & interprets a fully enclosed COTS sensor motor to be equivalent to a hard drive or fan.
