Go to Post All the gangstas in FRC have solid gold CRios. It's called "blingage". If you don't have a solid gold CRio, you're not a straight-up G. :D - Jamie Kalb [more]
Unread 12-01-2015, 19:15
BillTheSweeper BillTheSweeper is offline
FRC #1551
BillTheSweeper is an unknown quantity at this point
Pneumatics Control Module LED
Greetings,
The status LED on the pcm isn't strobing. Whenever we enable the robot in TeleOp, the LED continues to blink slowly instead of switching to strobe. The pneumatics along with the victors are unresponsive. We have no other components on the robot to test. We checked to make sure the wiring was correct. We are programming in C++, using the roboRio from this year's kit of parts. The code seems to work because printf output appears on the riolog. The channels we used for the victors matched the ports where we plugged in the PWM cables. Does anyone have any advice?
Thanks,
Bob the Sweeping Guy
