Go to Post There's more elegant ways to play defense than beating on the other robot. - Bill Moore [more]
Unread 12-01-2015, 11:01
mitchklong mitchklong is offline
None #4859
mitchklong is an unknown quantity at this point
Two wheel drive robot ?
Trying to overcome 2 design desireables:
- The desire to straddle the scoring platform (perpendicular)
- Have a robot dimension which exceeds transport config (32x32)
So what would happen if I just drive the back wheels (4 cim 2 boxes) and used omins in front ? Basically this would look like a commercial lawn mower.
The weight of the stacks would be toward the center of the bot.
Anyone done something like this ?
Unread 12-01-2015, 11:10
Re: Two wheel drive robot ?
I think you meant "accomplish"?
Search for the phrase "shopping cart" in these two threads:
http://www.chiefdelphi.com/forums/sh...d.php?t=132293
http://www.chiefdelphi.com/forums/sh...d.php?t=131862
Unread 12-01-2015, 11:23
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
1444 is considering a variation of this drive for Recycle Rush.
Unread 12-01-2015, 13:27
earlybird's Avatar
earlybird earlybird is offline
They tried to ship me 2 competition
AKA: Robbie Oehrli
FRC #2849 (Team Ursa Major)
earlybird is a jewel in the roughearlybird is a jewel in the roughearlybird is a jewel in the rough
We are thinking about doing a very similar thing with a wide chassis. I don't see the need to have power driven to the front two wheels because that just takes up extra weight and you don't have to push against other robots this year, just the totes. If you have time why not test both ideas? You could have a small piece of plywood angled at 16 degrees if you didn't build the scoring platform and push a tote that weighed 50 pounds up the ramp. If you are happy with how it preforms then you have found your solution.
On a personal note chain can be a pain some times to get just right and add a lot of weight and precision machining to the chassis. Just remember to always keep it simple! Our design over all at the moment uses 2 CIM motors, a compressor and 2 pneumatic pistons. We might bump it up to 4 CIMs but we aren't sure yet.
Robbie Oehrli
University of Maryland Baltimore County
B.S. Mechanical Engineering 14'
Maryland FLL Head Referee
Team 2849 Founding Member
Team 2849 Mentor
Unread 12-01-2015, 13:37
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
FRC 1625 ran a massively successful drive in this fashion last year. I remember from speaking with them that weight distribution was important, but I don't remember in what manner.
Unread 12-01-2015, 14:19
jvriezen jvriezen is online now
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
The OP stated a two wheel drive bot, with the rear wheels powered, but the omnis in front not powered at all. With scoring platforms and stray noodles, it seems any time you are on uneven ground (except when driving over a bump orthogonally) you'll have one wheel off the ground and this may reduce to a one wheel drive. With a four wheel drive, loss of wheel contact will only drop you from 4 wheel drive to 3 wheel drive.
Wouldn't this be a major issue?
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 12-01-2015, 15:10
Jared's Avatar
Jared Jared is offline
Good point. What if you tried three wheels? That way you'll always have the drive wheels on the ground (unless, of course, you bottom out). One unpowered omni wheel in the back and two powered wheels up front may work.
Unread 12-01-2015, 17:23
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Our Ultimate Ascent drive was like this. You should put the drive wheels on the end which is nearer the center of gravity for best traction and general performance. We had ours on the front, because we were front-heavy that year. Even then, when we tried to do a sprint, we found that we had much better control in reverse because the acceleration moves the weight towards the rear tires (as you're moving). So if your weight is centered, you will have better acceleration and control as you move forward. Unfortunately, you then give up braking traction, unless you figure out a way to brake the free-wheeling omnis.
Unread 12-01-2015, 19:09
TheThings's Avatar
TheThings TheThings is offline
AKA: Becky Daniels
FRC #0930 (B.E.A.R.s)
Team Role: Scout
TheThings is an unknown quantity at this point
Two wheel drive was my team's second option behind the drive train we're using this year. What ultimately decided it for us was the fact that unless you put the motorized wheels in the front, the weight from the totes will make the acceleration slow. The solution to that would be to put the motorized wheels in the front but that affects a driver's ability to drive. These two major downfalls made us ultimately decide two wheel drive was not for us.
Unread 12-01-2015, 19:22
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Just direct drive the rear tractions wheels and belt drive the front omnis
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
im confused what preventing you from doing a normal 4 or 6 wheel drive?
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 12-01-2015, 21:30
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Might want to re-read the section on transport configuration, those aren't the right limits for your dimensions.
The drive you are talking about can be very effective, we used it for 2 years and it worked well for a highly maneuverable robot. You might want to see how it handles the platforms, when we used it the field was flat and it might have issues driving straight onto the platform.
Unread 12-01-2015, 23:01
None #4859
Sorry those are my desired dimensions, with the key problem being either dimension over 28. We may end up 38x38 or something else square.
Q: Why not six wheels ?
A: Because if we drop the stack while perpendicular to the platform bot isnt level and the stack might might tip over. Also want to straddle platform for precision.
Q: Why not 4 wheel tank ?
A: To get around the 28' limit the wheels need to deploy out and dealing with
drive belts adds risk and complexity.
Q: What about traction/stablity issues
A: If center of gravity is rear of center wont that minimize those problems ?
Unread 12-01-2015, 23:39
Professional Stat Padder
I'm not sure why your drivetrain would need to exceed the transport configuration in-game. It seems like an extra engineering challenge for no good reason (I know we've already got plenty of those to deal with).
A 2-powered-traction/2-unpowered-omni drive should work fine for this game. Make sure you understand the trade-offs involved, especially when making a drivetrain decision.
If any system on your robot works, make sure it's that one (That also means that if any system on your robot might compromise the effectiveness of your drivetrain, the other system should generally be the one changed).
(2015-Present)
Unread 12-01-2015, 23:52
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Might want to re-read the section on transport configuration, those [32"x32"] aren't the right limits for your dimensions.
I believe that they are planning to transport their robot in a different orientation than that which they deploy on the field - a dreadfully simple solution, if you can figure out how to be no more than 28" tall.
I can certainly imagine some elegant "large base, bottom stacker" solutions which ship under 28" tall (and some which never get taller) yet deliver a stack of six totes to the backstop for efficient stowage. Alas, our design is pretty much locked in by the orders we've placed at AndyMark. I have to remember that perfect is the enemy of good enough...
