Go to Post In the end engineering is what happens between your ears, not what you build with your hands, not what a machine spits out. - KenWittlief [more]
Unread 12-01-2015, 18:49
nfusselman1 nfusselman1 is offline
FRC #4076
nfusselman1 is an unknown quantity at this point
[ERROR] Deploy Code
I am trying to deploy the "Intermediate Vision" Program and I am getting this error.
Buildfile: C:\Users\Developer\workspace\Intermediate Vision\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\Developer\workspace\Intermediate Vision\build
compile:
[mkdir] Created dir: C:\Users\Developer\workspace\Intermediate Vision\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\Developer/wpilib/java/current/lib/WPILib.jar:C:\Users\Developer/wpilib/java/current/lib/NetworkTables.jar to build
BUILD FAILED
C:\Users\Developer\wpilib\java\current\ant\build.x ml:69: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK.
It is currently set to "C:\Program Files\Java\jre1.8.0_25"
Total time: 4 seconds
I then went and changed the "JAVA_HOME" to the JDK and got this error.
clean:
compile:
Unread 12-01-2015, 19:00
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: [ERROR] Deploy Code
It appears as though your JAVA_HOME environment variable points to a JRE (Java Runtime Environment) instead of a JDK (Java Development Kit).
First, make sure that you have a JDK (preferably JDK 8) installed.
If you do, update your computer's JAVA_HOME environment variable to point to that. The path should be something like C:\Program Files\Java\jdk1.8.0_25
Team 2052- KnightKrawler
Mentor and volunteer
Unread 12-01-2015, 19:04
FRC #4076
on the second try I had done that and still got an error.
Unread 12-01-2015, 19:23
The second try doesn't show an error message. Please post what was printed after the posted part.
Unread 12-01-2015, 19:26
FRC #4076
oh but why does the driver station say that there is no code.
Unread 12-01-2015, 19:50
FRC #4076
NVM I got it to work now
Unread 12-01-2015, 23:22
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Just curious what did you do to get it working in case anyone else has this problem ?
Unread 13-01-2015, 11:39
FRC #4076
Here are the instructions.
1. click "start"
2. right click "computer"
3. click "properties"
4. click "advanced system settings"
5. click "environment variables"
6. if "JAVA_HOME" is in the system variables then go to step 12
7. else click "new"
8. "variable name" = "JAVA_HOME"
9. "variable value" = the location of your Java JDK it is close to "C:\Program Files\Java\jdk1.8.0_25"
10. click "ok"
11. your done
12. click "JAVA_HOME"
13. click "edit"
14. make sure the "variable name" = "JAVA_HOME"
15. make sure the "variable value" = the location of your Java JDK it is close to "C:\Program Files\Java\jdk1.8.0_25"
16. click "ok"
17. your done
Best of Luck!!
