Go to Post A Strong FRC Team Should... have a clear vision and an understanding of how to achieve it within their means. - jwfoss [more]
Unread 12-01-2015, 17:39
stwilliams333 stwilliams333 is offline
FRC #1466
stwilliams333 is an unknown quantity at this point
Window Motor Hub Help
I am attempting to make a custom CAD file to work with the KOP window motors (model number 262100-3040). I want to make a special spool hub for it, based on a model of the original hub. I have searched online and have been unable to find a model of the hub. Could anyone direct me to a model of the hub? I can't even find a model number for the hub, only the motor.
Thanks!
Unread 12-01-2015, 17:58
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Re: Window Motor Hub Help
I have a Solidworks part that couples the Denso window motor to a hex shaft...is that useful? 3D printed it last year, but it didn't end up on the bot. It worked, though.
I posted it on Thingiverse:
http://www.thingiverse.com/thing:632851
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 12-01-2015, 19:01
FRC #1466
While I don't need a coupling, I can make a model of the rest of the hub around the end that connects to the motor. Thank you!
Unread 12-01-2015, 20:12
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
If you are unable to work with the file from thingiverse let me know. I have the same kind of adapter we made for our ball retrieval arm on last years robot. I have the file in STEP and Inventor. It will be easy to remove the hex end and just keep the denso star portion.
Good luck with this. Do remember that PLA is not very strong so make sure you are dealing with the load in a mechanism prior to the adapter. You can try ABS if you able to print with it. We went through a few of these adapters by worlds due to this. Luckily we designed the arm to allow easy access to the adapter and just printed a bunch and changed them out as needed. Not ideal but worked well enough.
Good luck this year!
Aloha
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 14-02-2015, 09:14
sethbattis sethbattis is offline
FRC #3566 (Gone Fishin')
sethbattis is an unknown quantity at this point
We've been noodling at this problem too.
https://github.com/frc3566/team3556-...20Motor%20Hubs
You're welcome to use anything we've got in there. In terms of strength, we're pretty confident in our ABS 3D-printed denso-to-1"-square-tube connector. We're still fine-tuning the denso-to-gates-pulleys hub.
