Go to Post So I guess this is just another case of someone reinventing the leg? - petek [more]
Unread 12-01-2015, 20:49
Pius5652 Pius5652 is offline
FRC #5652
Pius5652 is an unknown quantity at this point
Right Side Talon Motor controllers won't work together
Hello everyone
When connected with the Y-split wire, one of our right side Talon motor controllers is flashing indicating loss of connection to roboRio. Left side is working fine. We were told that the two Talons on the right side may share the same device ID s in the roboRio.
Any help to solve the problem would be greatly appreciated
Pius
Unread 12-01-2015, 21:00
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Re: Right Side Talon Motor controllers won't work together
I would try a different wire. The PWM pins have a tendency to misalign.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 12-01-2015, 21:02
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
For CAN bus use...
Talon SRX's cannot share device IDs with each other.
Please read section 3.1 of the talon srx software reference manual...
3.1. Programming API and Device ID...
For the robot to function properly, there CANNOT BE “COMMON ID” Talon SRXs....
By Y-cable do you mean just regular CAN bus chaining?
...or are you trying to use PWM?
Unread 12-01-2015, 21:10
Are you using PWM or CAN? Are you using Talon SR or Talon SRX?
Assuming the former in both cases, I've seen 2 cases of bad PWM y-cables this year.
Unread 12-01-2015, 22:42
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
If you are using pwm cables switch them. I had the same issue and realized it was a bad connection in the standard pwm cable
