Go to Post I don't need sleep, just more Mountain Dew. Oh, and a muffin. - hallk [more]
Unread 12-01-2015, 18:26
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Vision in Java
First, a disclaimer: I am not a programmer. I am a mechanical mentor dipping my toe into the programming side to help set some wheels in motion for a vision system.
My team is 100% Java. For a variety of reasons we have decided to program in it exclusively.
There are lots of choices for implementing a vision system. On the roboRIO vs on the driver station vs on a co-processor. If on the DS, it could be in roboRealm, NI's code, or something else. I'm not familiar with the individual requirements or pros/cons for each of these options.
My question: as a pure Java team, what is the path of least resistance for getting a vision system up and running? We've never done one and I want to make sure we get something implemented this season, even if it is very basic.
Thanks.
Unread 12-01-2015, 21:55
SquishyIce's Avatar
SquishyIce SquishyIce is offline
FRC #1405 (Finney Falcons)
Team Role: Electrical
SquishyIce can only hope to improve
Re: Vision in Java
If you're just looking for getting vision on your dashboard with a USB camera, I stripped down the SimpleVision template to 3 lines of code that you run when initializing everything:
CameraServer camera = new CameraServer();
camera.setQuality(50);
camera.startAutomaticCapture("cam0");
When you start up the driver station while connected to a RoboRIO running this code, go to the FRC PC Dashboard. In the bottom left of the "drive" pane, there should be a dropdown menu with the options of no camera, SW camera, HW camera, and IP camera. I believe you set this to SW camera (If that doesn't work, try HW camera. It's one of the two. I honestly cant remember, even though I was using it literally 2 hours ago). This should give you a live camera feed in what was formerly a big empty space of the dashboard. One thing I did notice tonight about that string "cam0"; this does not name the camera, it determines what camera to get the feed from. I believe the first camera you connect is automatically addressed as "cam0". I could be wrong on this, I haven't tested using multiple cameras. I learned this the hard way by replacing "cam0" with "PotatoCam", then not understanding why I couldn't get any feed whatsoever.
Good luck!
"MAKE IT WORK, DAVID"
Unread 12-01-2015, 21:57
Jared's Avatar
Jared Jared is offline
Re: Vision in Java
Personally, I love team 341's solution to vision in 2012. They ran it on a dashboard that runs on the driver station. It's written in Java and worked very nicely. In my opinion, 341 was one of the most impressive robots to watch.
Unread 12-01-2015, 22:11
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: Vision in Java
I'd second that statement. 341's system was the inspiration for our vision system last year, which was purely in Java. Instead of writing a SmartDashboard plugin, though, we used the Java bindings for OpenCV and NetworkTables to write a Swing app that ran on the driver station. Here's the code if you're interested: https://github.com/LuNaTeCs-316/LuNaCV
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 13-01-2015, 01:16
craigboez's Avatar
Mechanical Engineer
Re: Vision in Java
Thanks, I'll take a look at the Daisy implementation. I have heard that JavaCV is poorly documented, at least relative to OpenCV. Has that been your experience?
Unread 13-01-2015, 02:54
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Vision in Java
It definitely is not as well documented as it is for c and cpp! I might have a vision solution so if it works I will document it and polish up for other teams to use!
Unread 13-01-2015, 10:01
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Vision in Java
I wouldn't use JavaCV (the old third-party Java wrappers) because they only support OpenCV 2 and there is now an official Java API. It does not have its own documentation but the C++ documentation applies to it as well in most cases.
Unread 14-01-2015, 10:00
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Re: Vision in Java
This. I've noticed a few changes, specifically that there is no IplImage anymore (Mat is the new storage type of choice) and imread/imwrite is in Imgcodecs.
