Go to Post FIRST, an american revolution. - paulcd2000 [more]
Unread 09-01-2015, 21:33
Bluejackets's Avatar
Bluejackets Bluejackets is offline
Bluejacket Robotics
FRC #5464 (Bluejacket Robotics)
Rookie Year: 2015
Bluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to behold
[FTC]: Starting an FTC team which platform?
We are going to teach robotics as a high school class next year in grades 9-12 in our school and I am wondering what platform would be best to use. VEX, Tetrix etc... Before we spend a ton of money on one platform I just thought I would see what opinions are out there.
In addition, We also want to start up an FTC team next year and currently we are involved with FRC at our school. In the future we hope to expand into the middle schools and elementary with FLL
I am the lead instructor and my background is teaching VEX within a classroom setting but I am wondering what would you recommend for a new school starting up an FTC team. Maybe a combo of different platforms. Any advice.
I appreciate your time.
Unread 10-01-2015, 09:59
Sasha Sasha is offline
AKA: Alexander Kirillov
FTC #4137 (IslandBots)
Sasha is just really niceSasha is just really niceSasha is just really niceSasha is just really niceSasha is just really nice
Re: [FTC]: Starting an FTC team which platform?
You can mix and match all components except the electronics - battery, motor/servo controllers, motors. For that, you need to choose either Tetrix or Matrix - no mixing allowed.
I would suggest Tetrix as the main platform (battery/controllers, axles, gears,...) with AndyMark Neverest motors. For structural pieces (beams, channels...) you can use tetrix, t-slot aluminum profile, or servocity Actobotics set - take your choice. We are using 20mm t-slot aluminum, plus a lot of just aluminum profile from HomeDepot whcih we cut and drill as needed.
FTC 4137 "Islandbots"
islandbots.org
Unread 10-01-2015, 21:10
Bluejacket Robotics
Rookie Year: 2015
I am new to all of these but I have used to the VEX platform. What are the advantages of Tetrix or Matrix over VEX. Thanks for your help
Unread 12-01-2015, 16:38
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
The Vex Platform is a lot cheaper. Which is part of the reason my teams stay away from joining vex....
We have fallen in love with FIRST over the 7 years that our team has been competing. We have looking into doing vex, but we just don't find the community there, as well as the robots pretty much looking the same every year. There seems to be a lot or restriction on build types and the games themselves.
So FTC. Granted your going to be a first year team, so Tetrix will probably be your best option. Matrix is more of the off-brand that is cheaper for over-sea teams. (The motors are weaker than tetrix, as well as plastic gearing, etc.)
But we don't use either the Tetrix or Matrix platforms. We have found it to be much cheaper for us to custom build all of our robots from factory based items. (1x1 tubing/2x1 tubing/angle/etc.) The only thing we use of tetrix is the required items, Control Boxes, Nxt, etc. We have switched to the new Andymark motors as well. Much cheaper when you factor in the encoders that most of our autonomous programming needs.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 13-01-2015, 00:27
PHFTC PHFTC is offline
FTC #8045
PHFTC is an unknown quantity at this point
If you don't want to manufacture everything, and were starting FTC without parts, the variety in the Actobotics line of parts sure seems appealing. You'd need the base electronics (kit) from Tetrix, but the rules now let you use most of the Actobotics hardware. Both offer discounts for FTC.
Unread 13-01-2015, 00:48
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I like FTC. If you're already doing FRC, the competitions and community feel a lot closer-- in MN at least, a good deal of FRC teams also have FTC teams, volunteer at or host FTC competitions, etc. In our area at least, VEX isn't nearly as popular, so FTC is the easiest choice.
As for parts, with FTC, Tetrix is a perfectly serviceable kit for a rookie and many veteran teams. I would strongly suggest using the AM NeveRest motors instead of Tetrix DC motors-- they're basically impossible to burn out, have a built in encoder, and are generally superior in just about any context IMO.
Moving forward however, I'd definitely suggest taking advantage of the expanded COTS rules from the last few years. You can use basically any type of aluminum extrusion, all the way from .5"x1" rectangular tubing to 6" circular tube. Especially if you want to train FTC kids for FRC, using these options is a very good idea.
Good luck, and have fun in whatever competition you choose.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
