Go to Post There's lots of other "stuff" that make a team work well in the FIRST environment, beyond designing and building a robot. - KathieK [more]
Unread 13-01-2015, 02:08
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
Bigger Compressor
As my team and I do more and more research into making a reliable pneumatic system because our robot will rely heavily on pneumatics we realised the "stock" compressor kinda sucks. I know there is the CFM limit but is there any better compressors out there?
Unread 13-01-2015, 07:46
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Bigger Compressor
There have been a number of discussions about compressors in the past, the most recent one is here. The standby for me will always be the old Thomas compressor from the kit of parts, however we have purchased and really like the Viair 250C-IG (it's significantly larger and heavier then the current KOP compressor).
Unread 13-01-2015, 08:20
As a caveat, the Viair above comes with a stainless steel hose that is required for operation by the manufacturer. The hose helps dissipate the heat generated by the compressor and compressed air.
Unread 13-01-2015, 10:06
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
We used the Vivair 90 last season on our robot and had no problems with it. The trick is to blow some air across the heat sink to keep it cool.
For reference most of our robot ran on pneumatics. Shifters, wings, pickup arm, and the catapult. We used a lot of air.
Unread 13-01-2015, 10:12
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
As I mentioned in another thread, my feeling is that this year, pneumatics will work fine for "grabbing", but not for "lifting". The amount of work that needs to be done to stack totes and containers is pretty high, and the compressor just can't keep up with air demands.
I could be wrong, but you ought to at least do some power calculations. Be sure to derate the compressor's flow rate for the pressure it will be operating at, there is a CFM vs PSI chart for it somewhere. And beware that pneumatics is a rather inefficient way to do work, there is lots of loss both in compressing the air, and in the cylinders moving back and forth. There are tricks you can play to help, but it will still probably be marginal. We had an almost fully pneumatic robot last year, with a much lighter game piece, and had trouble with running out of air.
Speed will be vital this year for getting lots of points, you don't want to be waiting around for the compressor to build pressure.
Unread 13-01-2015, 10:53
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
MrForbes is right. You need to think very carefully about designs that need lots of air to work.
One thing we've done in the past to help the compressor out is to run a fan blowing on the heat sink. Not so much during matches as when you're testing in the shop -- most of the legal compressors are rated for very low duty cycles and get quite hot. We started doing this after we melted the tube leading from the compressor.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
