Go to Post We all know that with mechanical systems, once all the noise has leaked out, the system quits (therefore quiet running mechanical systems last much longer :^) - KenWittlief [more]
Unread 13-01-2015, 09:33
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Re: Code Deployment Error
I'm a college student so I can't go test stuff. But I can see the concern, and why we need to fix this asap. When we first created a testbed project we just switched it to tank drive, and added a 2 solenoid pneumatics system. T
That is the extent of this little program.
The next thing we did was tether via USB, then build and deploy the project. any project that we would build and deploy would return the error from the first post. The IP being: roboRIO-876.local. This is the IP that it should be responding to correct?
I'm just confused, because in years past when the cRIO was 10.xx.yy.2, this is what I expected this year.
