Go to Post ... as teammates we often get too into the craze of competition and forget that this wouldn't happen without so many dedicated people. - miketwalker [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 13-01-2015, 11:26
The_Drive_DR The_Drive_DR is offline
FRC #2036
The_Drive_DR is an unknown quantity at this point
Drivetrain is Making a Horrible Noise
We are building the kitbot drivetrain and chassis. The right side is aligned perfectly and is pretty quiet but the left side squeaks a lot. It sounds terrible. We have tried taking the left side apart and re-aligning the bearings greased the gearboxes and stuff of that nature, but nothing really helps. The noise was a little better after we greased the gearboxes but it returned a day later. Any thoughts?
Unread 13-01-2015, 11:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Drivetrain is Making a Horrible Noise
post video to youtube....???
Unread 13-01-2015, 11:32
FRC #2036
I don't have a video and am not in the lab but i will post one later today.
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
Sometimes your gearboxes just need to be broken in.
Unread 13-01-2015, 11:36
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The gears have a shoulder. It is possible to put them together with the shoulder on the wrong side, causing interference problems.
Unread 13-01-2015, 11:43
Did you triple-check to make sure steps 3, 4, and 7 were done properly?
ID:	17827  Click image for larger version
ID:	17828  Click image for larger version
Unread 13-01-2015, 16:17
hobbes20xxx hobbes20xxx is offline
AKA: Josh
FRC #2075 (Engima)
hobbes20xxx is an unknown quantity at this point
If rebuilding and double-checking the shoulder placement doesn't help, try replacing your bearings.
We had the same problem this year and it turned out we had a bad bearing.
Unread 13-01-2015, 16:29
FRC #2036
Ok I will try replacing the bearings. I have double checked that the the gears are facing the right way. Thanks!
Unread 13-01-2015, 16:56
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Using the TBMini a year ago we had one that made a horrible grinding shrieking noise. We loosened the CIM motor bolts and applied pressure to pull it as far to the side as possible, making there be less pressure on the next gear. We then tightened the bolts and the noise was greatly reduced.
Using other TBMini gearboxes in the off-season we've had similar noisiness.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
