Go to Post HOSE CUTTER: A tool used to make hoses too short. . - dlavery [more]
Unread 13-01-2015, 11:54
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
paper: Visual Center of Gravity Calculator
Thread created automatically to discuss a document in CD-Media.
Visual Center of Gravity Calculator by Ben Martin
Unread 13-01-2015, 11:58
Ben Martin's Avatar
Re: paper: Visual Center of Gravity Calculator
Instructions:
- Add whatever colors and weights to the list on the far right
- Use the excel "zoom" feature in the bottom right to help get around the worksheet
- Everything has range names--change formatting as you wish for everything that doesn't have a "named" range
- Everything is weighted equally across a color. So, if your arm stretches across across the page, each cell in the arm will carry equal weight. If one part of your subsystem is heavier than another, you can split them into separate subsystems.
- Each square on the map represents one inch
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 13-01-2015, 16:32
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Thanks for sharing
We typically just CAD the robot and calculate CG.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
