Go to Post you might want to consider the Edu-Robo-Whatevertheheckitscalled RC - Matt Krass [more]
Thread Tools Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Unread 11-01-2015, 14:20
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
Talon SRX Encoder Breakout
I had a question about the SRX breakout board for the new talon. Located here http://www.vexrobotics.com/217-4398.html
TChey way I understand it is you could add an encoder right to the tallon and it woudl process the signal on to the CAN bus.
Correct me if I am wrong, the encoder would still be on the mechanical side to monitor the actual movement of the saft it will just feed data to directly the controller instead of directly to the myrio.
Unread 11-01-2015, 15:14
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: Talon SRX Encoder Breakout
Yes i believe your right but I with this I believe you can also just have the PID control on the motor controller itself (eg keep a wheel spinning at 70 rpm)
Unread 11-01-2015, 15:26
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The reason to run the encoder to the talon is the same for the Jags. You would run the PID in the Talon. Otherwise you would run the encoder into the RoboRio.
Unread 11-01-2015, 15:31
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Also, because you can get the raw encoder values at any time, you can plug the encoder into the talon, then still do the PID calculation on the roboRIO. This has some interesting use cases, and could both simplify wiring, and require less IO's to be used for encoders.
Team 4488 - Mentor 2013-2016
Unread 12-01-2015, 08:50
amesmich's Avatar
FRC #4638 (Jagbots)
Wow, ok that makes sense. Its uses the encoder for the onboard PID. Nice. Originally I was thinking it would save an I/O and some wire but now I understand the PID can be offloaded from the myrio to the controller. I knew the new talon had PID but I never put the two together.
Thanks for the help all.
Unread 12-01-2015, 09:27
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
From a controls standpoint, I wouldn't recommend this for most cases. There will be an increased time delay between getting the encoder value from the Talon to the RIO and sending back the new control command. If you're going to use processing on the RIO, it's better to have the encoder wired to the RIO and use PWM. This is all to maintain the minimum possible time lag in the system.
Unread 12-01-2015, 12:22
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
The Talon SRX reports the sensor position and sensor velocity every 20ms. The control frame to the Talon is sent every 10ms.
If you are using C++/Java you can change these time periods. If you do this be sure to check the CAN metrics in the DS tab.
See sections 20.5 and 20.7 in the Talon SRX Software Reference Manual for details. Also section 15 for measuring CAN performance.
"Talon SRX Software Reference Manual 2014-12-26 (.pdf)"
http://www.crosstheroadelectronics.c...ol_system.html
Unread 12-01-2015, 12:30
Even if running 10ms loops on the RoboRIO, you will be at max 10ms behind the actual sensor. Thats not that much, and just like ozrien said above, we can speed up the controls to lower that to even less. I don't believe latency across the CAN line would account to more then 1ms, which is negligible.
Is there any timeline for when that functionality will be added to LabVIEW? That could be something good to have.
Unread 12-01-2015, 14:29
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Can I get some more details about this?
From what I read the values come back every 20ms. You get new values 50 times a second (20*50=1000ms=1 second)
The update rate is at 10ms, so you can update it 100 times a second, You are using slightly stale data.
At 10 fps (random robot speed that seemed reasonable) you will travel ~2.5 inches per 20ms period.
But you are not going to stop on a dime ( or turn on one) since your 120lb robot moving 10 fps has a lot of momentum.
Are the drive trains / actuators that sensitive to need higher update rates?
Or is this just a case of faster is always better?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 12-01-2015, 14:54
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
These links are dead for me; they redirect to the Talon SR product page. When I try to right click and save as to recover the .pdf files, it says that the files are damaged or unrecognizable upon attempting to open them. Our team would be interested in the information in these documents, but we are unable to access them.
In particular we are interested in how many pulses per second the Talon SRX is capable of reading from a quadrature encoder in CAN.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 12-01-2015, 14:58
ozrien's Avatar
Omar Zrien
AKA: Omar
Just to be clear you went to ....
...and clicked on the "Talon SRX Software Reference Manual 2014-12-26 (.pdf)" hyperlink at the bottom and it redirected to Talon SR?
Unread 13-01-2015, 13:17
AKA: Carl Springli
Exactly. When I hover over that link, it displays:
"www.crosstheroadelectronics.com/Talon SRX Software Reference Manual.pdf"
in the lower left corner of my browser (Google Chrome) in a gray box.
Then I click it and I end up here:
http://www.crosstheroadelectronics.c...e%20Manual.pdf
I'm no expert, but it might be helpful to change the " " (space) character in the file name and directory to an "_" (underscore). My browser seems to replace the space with a percent symbol and then direct me to the wrong page as a result.
Unread 13-01-2015, 15:00
Bob Steele's Avatar
AKA: Bob Steele
Where does this take you?:
http://content.vexrobotics.com/vexpr...l-20141226.pdf
It should take you to the software manual directly.
Unread 13-01-2015, 15:04
ozrien's Avatar
Omar Zrien
AKA: Omar
That's correct, space ' ' is encoded as %20.
Yeah I don't get it, both style paths seem to work for me, iexplorer and chrome.
crosstheroadelectronics.com/Talon%20SRX%20Software%20Reference%20Manual.pdf
Anyone else having trouble?
You can also just google Talon SRX Software Reference Manual.
Also it's on vex's site
http://www.vexrobotics.com/217-8080.html
Unread 13-01-2015, 17:31
AKA: Carl Springli
I am able to access it from the vexpro site, thanks for pointing that out.
