Go to Post It is great to be proud of the way you do things, but to imply that everyone should match your way of thinking, is ludicrous. - JVN [more]
Unread 01-13-2015, 02:53 PM
Kingston951 Kingston951 is offline
FRC #1943
Kingston951 is an unknown quantity at this point
Program robot code on Linux
Has anyone succeed running eclipse on Linux with WPILib ?
And which apt-get should I use ?
Unread 01-13-2015, 10:39 PM
fsilberberg fsilberberg is online now
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: Program robot code on Linux
Most of the WPILib team uses Linux, it works fine for us. apt is a command line tool for installing packages. You need to use it to install the toolchains on Linux. Follow the instructions here: http://first.wpi.edu/FRC/roborio/too...0Toolchain.txt
