Go to Post Even as a "mentor", I am still being mentored by engineers who work with the team. - Tom Bottiglieri [more]
Unread 13-01-2015, 10:38
Re: How fast was the fastest mecaum?
Originally Posted by FrankJ View Post
In a frictionless physics lab I would expect the free speed between the field (carpet?) & hall wall (tiles of other hard surface?) to be the same.
I wouldn't.
The compliant flooring (carpet) moves slightly as the mec rolls forward over it, due to the tranverse force component exerted by the roller. This motion is accompanied by roller rotation, which subtracts from forward motion somewhat.
That's the theory anyway. It would be enlightening to see a controlled test to investigate the magnitude of this effect quantitatively.
Unread 13-01-2015, 10:44
Originally Posted by silverD View Post
(11.77 ft/s adjusted)...(14 ft/s adjusted).
did you do any actual speed measurements?
Unread 13-01-2015, 10:49
silverD's Avatar
silverD silverD is offline
Build Mentor
AKA: Nate
FRC #2052 (KnightKrawler)
silverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to behold
Ether,
Sorry to report we didn't. These numbers are based on the JVN calculator.
Unread 13-01-2015, 11:01
I suspected as much, but hoped otherwise.
We are trying to establish whether or not the 81% "speed loss constant" is a reasonable value to use for mec on carpet.
Unread 13-01-2015, 11:45
silverD's Avatar
Build Mentor
AKA: Nate
I agree, this would be great to know. We hold driver practice on competition carpet. I suppose we could mark out the carpet, capture video, and try to get some numbers.
Unread 13-01-2015, 15:54
Bob Steele's Avatar
AKA: Bob Steele
Smile Re: How fast was the fastest mecaum?
In a frictionless physics lab I would expect the free speed between the field (carpet?) & hall wall (tiles of other hard surface?) to be the same. In the world the wheels may not be perfectly aligned. The macanum rollers turns more freely on a hard surface rather than carpet. All this create side forces. The side forces net out to zero but consume energy thus a lower speed.
In a frictionless physics lab the mecanum drive would not move the robot.
velocity would be zero
Unread 13-01-2015, 16:07
I assume this was intended to be humorous. Frank certainly did not intend to imply that the friction between the floor and the wheels is zero.
Unread 13-01-2015, 16:29
Bob Steele's Avatar
AKA: Bob Steele
You might take it to be humorous... but as a physics teacher I would like specificity.... I see many statements on CD that sound "right" but make little sense. (note... not from you Ether... you are quite good at getting to the specificity of the issue)
Do the side forces from the mecanums really "cancel each other out"
The net force accelerates the robot. side forces oppose each other but that energy goes somewhere. Has anyone ever felt mecanum wheels after prolonged driving? Conservation of energy is real.
Just a comment... not a condemnation....
Unread 13-01-2015, 16:45
Yes they do.
Force is not energy. If there's no motion in the direction of the force, there's no energy involved.
That's due to friction in the rollers, roller axial free play, and floor compliance.
Unread 13-01-2015, 16:50
I can relate to that. As a graduate student at a major engineering university back in the 70s, I taught physics to EE students.
Unread 13-01-2015, 17:05
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
Ether is right. I use the term "frictionless physics lab" to mean I am ignoring trivial & sometime not so trivial factors to simplify the discussion.
In a truly frictionless lab, velocity for mecanums on a hard surface would be zero. On carpet it would be somewhat less than zero since the compliance in the carpet would give some forces not dependent on gravity.
The angled wheels gives you side force vectors. If the forces are not canceled out, then the robot accelerates in reaction to those forces. Especially in a frictionless physics lab.
My high school physics teacher thought I only took physics to play with the toys. He was largely right.
Unread 14-01-2015, 01:05
SpeedFreed's Avatar
SpeedFreed SpeedFreed is offline
Coach Annoyance Lead
FRC #0418
SpeedFreed is an unknown quantity at this point
Originally Posted by asid61 View Post
How did strafing go? Even if it was slower than straight, how fast was it? Did you run a suspension?
Strafing was pretty slow. Keep in mind this was with single speed gearboxes (yes single speed, geared to 20.5 FPS, and mecanum), so strafing was probably no more than 8-9 FPS (this number is entirely guestimate). This was, however, on the set of mecanum wheels with nearly 75% of the rollers broken. All this being said, we still ran it with FOD (nav6), and I (the driver) thought it was great.
Also, we didn't use suspension. I find that making the frame loose, adding suspension, etc, to be pretty unnecessary. The Vex mecanum wheels have that extra flex in them which I think is sufficient to replace the above (at least it was fine for us). I would still make sure it is as flat as you can make it when putting it together though.
How did you measure the actual speed? e.g. video, stopwatch, etc?
Testing was, well, far from scientific, in that we ran it down the hall way a couple times and timed it with stopwatch on a phone. I'd give it a good ± 1 FPS or so. A similar approach was used on carpet.
Originally Posted by Jay O'Donnell View Post
Was this due to never having enough space/time on the field to accelerate to your full speed? That would be a problem this year since the field will get cramped and there won't be room to accelerate much.
Both carpet, and non-carpet tests were done over similar distances. I am pretty sure it was due to the extra loss in energy to the carpet (or perhaps to the gobs carpet fuzzies in the gearboxes) Regardless, I 100% do not recommend this set up for this year.
Unread 14-01-2015, 01:25
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
I would also second checking with 2052. They seem to have Mecanum down pat.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 14-01-2015, 02:51
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Those are heartening results. We'll have to order a few different gear and sprocket sets for ours then.
