Go to Post For those of you that think the kit chassis is too weak... It is tough stuff. Those of you that say it is too weak, just do not know what you are talking about. - Paul Copioli [more]
Unread 13-01-2015, 16:51
ItsTebowTime ItsTebowTime is offline
ItsTebowTime is an unknown quantity at this point
[FTC]: Gyro Position Question
Hi: I just finished writing a code for using the Gyro sensor to turn more accurately in autonomous. Unfortunately I can't mount the sensor in the direct center of the robot because of our lift. If I have it centered between the drive train (left to right) and centered vertically, is it okay if it isn't centered front to back (mounted on the very back of the robot)? Thanks.
Unread 13-01-2015, 16:57
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Re: [FTC]: Gyro Position Question
The Gryo Sensor does not need to be centered in the robot. Ours is on the right side, of the robot and still works correctly.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 13-01-2015, 21:02
Great: thank you very much!
Unread 13-12-2015, 15:44
docdavies's Avatar
docdavies docdavies is offline
Doc Davies
FRC #0346 (RoboHawks)
docdavies is an unknown quantity at this point
Can you tell me how you implemented a gyro in FTC?
What sensor did you use, and how did you interface it to the new Android control system?
