Go to Post "Splet" is the sound a frog makes when it hits pavement at 187 feet per second. Don't ask me how I know. - dlavery [more]
Unread 13-01-2015, 14:32
3543Katie 3543Katie is offline
FRC #3543
3543Katie is an unknown quantity at this point
Question How to make Lead Screws work
I am new to building robots and am making a lift device. I really need help because I don't know how to make lead screws work. I need to know how to power them, and how to attach them onto a arm/ forklift. Also what parts I will need. If you could help me I would love you forever.
-Katie
Unread 13-01-2015, 14:49
TylerS's Avatar
TylerS TylerS is offline
AKA: Tyler Stark
FRC #1747 (Harrison Boiler Robotics)
TylerS will become famous soon enough
Re: How to make Lead Screws work
Are you dead set on using a lead screw? If you're planning on making a mechanism to lift totes there are many other COTs products that are available specifically tailored to FRC that will be much easier, cheaper, and lighter to use than a lead-screw mechanism.
Purdue University 2019 - Aerospace Engineering
2016 - Team 1747 - Design & Build Mentor
2015 - Team 303 - Coach/Build Captain
2014 - Team 303 - Build Captain
2013 - Team 303 - Driver
2012 - Team 303 - Programming Leader
Unread 13-01-2015, 14:55
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Well we are considering using a lead screw as well and I for one don't think there is a weight penalty. The conundrum I have is trying to figure out much power I need to turn the thing.
The JVN calculator is not usable for this as far as I can tell.
Can someone provide some math for this or a lead screw power calculator?
Thanks
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 13-01-2015, 15:02
TylerS's Avatar
AKA: Tyler Stark
Thanks
You're right they can be made quite light, I spoke too soon.
Unread 13-01-2015, 15:14
pfreivald's Avatar
AKA: Patrick Freivald
Thanks
https://www.youtube.com/watch?v=FUNFcvnKQ-Q
Right at the beginning of this video, you can see our lead screw-controlled claw (something I wouldn't recommend for a variety of reasons--it was far too slow for that application, and complete overkill on torque--but we considered it for a lift this year). The motor and planetary gearbox are attached directly to the non-mobile part of the robot, and the nut is attached to (and able to pivot on) the "elbow". As the screw turns, the nut rides up and down on the screw, forcing the distance to change and thus pivoting the claw.
For a forklift, you'd have a simpler setup: The motor would mount in line with the carriage motion, at one end. The carriage would contain the nut, and as you turned the screw you'd lift the carriage up and down.
Calculating the torque/speed at any given power requires treating the lead screw like an inclined plane to calculate the mechanical advantage. (So if a single rotation of the screw has a circumference of 1 inch, but the nut moves .5", you have a 2:1 reduction.)
Efficiency really matters, though--they tend to be resistant to backdrive, but slower than you expect them to be, especially under load or if the screw bends.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 13-01-2015, 17:35
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
The JVN calculator is not usable for this as far as I can tell.......
For an approximation** I use the Linear Mechanism tab, and adjust pulley diameter and gear ratio for the turns per inch of the leadscrew.
For pulley diameter I use 1/pi (.318) (forces the spreadsheet to 1 unit of revolution to 1 inch of travel)
Then in addition to whatever gear/sprocket/belt ratios you are using to drive the shaft, add a gear ratio (Drivingriven) of 1:[tpi of screw] (1:5 for a 5 tpi acme screw)
**This does not take into consideration friction/loss of the leadscrew, which could be very high (steel screw/nut needing lubrication) or low (ballscrews, etc) so design conservatively.
Unread 13-01-2015, 17:46
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Thanks
Manufacturers often have papers like this to help with using the products.
http://pic-designcatalog.com/images/.../section_3.pdf
http://www.sdp-si.com/D810/PDFS/Ball...l%20Inf o.pdf
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
Unread 14-01-2015, 07:54
mentorDon's Avatar
mentorDon mentorDon is offline
FRC #1764
mentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these parts
There is some excellent information in the PIC design catalog pdf. I would also suggest to make your design using the screw in 'tension' instead of 'compression'. If your design forces are compressing the screw, use the MAXIMUM COMPRESSION LOAD vs. LEAD SCREW LENGTH graph on page 3 to determine buckling limits. As an example, using a 3/8 dia screw with a force of 100 pounds, the maximum screw length using the 'A' method (fixed - free), is about 12 inches.
Unread 14-01-2015, 11:03
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
A lead screw will easily work, but you will need a lathe do some machining on the screw ends for bearing supports. I’d suggest driving it with a ~ 40:1 gearing and an HTD pulley or chain sprocket drive.
IGUS has hardware and design guides.
http://www.igus.com/wpck/3556/drylin...zgewindemutter
Unread 14-01-2015, 11:34
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
I had contacted igus for recommendations, and help calculating, but seems the team is going a different direction. I'm electrical mentor, so don't ask any questions of me, just posting as it may help others.
I was hoping for a solution that would not backdrive, but to get the speed we wanted 2 seconds up, 2 seconds down, that was not going to work, so if you use this solution you will need to power motors 100% of time or add some brake mechanism to hold the load.
- How far apart will the 2 lead screws be located?
Distance between the two lead screws will be between 18" and 22"
- Where will the center of gravity be in relation to the nuts?
The cg of the totes will be 2" off the center of the nuts.
- Will you be using a liner guide as well?
Yes, we plan on using some Alum extrusions (Acme, 80-20 with their slides componets)
Please confirm?
- 60 lb load
- 2 foot stroke
- 1 foot/second
Due to the speed a high helix nut will be needed. Unfortunately the high helix are not available in the anti-back lash version. Please advise and I will get the report over to you.
The sooner we get behind schedule, the more time we have to catch up.
Unread 15-01-2015, 22:51
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of light
http://firstchoicebyandymark.com/fc15-037
they are out of stock now. but you can look up the specs
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 15-01-2015, 23:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
You could go with ballscrews if you have the cash. Low backlash (almost none, like 0.003" at the worst) and higher lead, and hugher max speed.
Unread 16-01-2015, 00:28
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
We have a calculator on our site to help determine speeds and forces: http://dartactuators.com/calculations-actuators/
You can also download our step files to see some of our design considerations in using a lead screw.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 16-01-2015, 11:25
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
In 2013 we machined the end of a lead screw into a 1/2in hex and mounted it in a typical FRC hex bearing and drove it with a VexPro gear with a 1/2in hex. Everything was sandwiched together with a 10-32 cap screw in a hole tapped into the lead screw. It was drive by 2 CIM motors and a 775+cim-u-lator with a single gear reduction, around 16:72. 72t gear being mounted on the lead screw.
It worked well, we had no issues all season with it.
