Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
Unread 13-01-2015, 19:45
H$H4RK H$H4RK is offline
FRC #4103
H$H4RK is an unknown quantity at this point
Question How to display Microsoft webcam on frc driver station camera view
Hello, I am new to FRC and i am wondering how do i display image feed from a microsoft HD webcam plugged in into the usb port on roboRio to the camera view option on FRC driver station.
Unread 13-01-2015, 19:48
Re: How to display Microsoft webcam on frc driver station camera view
What language are you programming in?
Unread 13-01-2015, 20:05
SquishyIce's Avatar
SquishyIce SquishyIce is offline
FRC #1405 (Finney Falcons)
Team Role: Electrical
SquishyIce can only hope to improve
/http://www.chiefdelphi.com/forums/showthread.php?t=132714
My reply on this thread turned out to not be as relevant as I thought towards OP's question, but maybe it can help you. DISCLAIMER: This is java-specific. You might want to specify what language you're coding in.
"MAKE IT WORK, DAVID"
Unread 14-01-2015, 20:20
FRC #4103
I found a solution at http://www.chiefdelphi.com/forums/showthread.php?t=132686 turns out there is no need to code if you are using the default dashboard to display the camera view
Unread 14-01-2015, 23:00
Correct, if you are using LabVIEW.
Unread 15-01-2015, 10:47
FRC #4103
One more question: do the Microsoft USB camera take less bandwidth than the axis cameras?
Unread 15-01-2015, 18:49
FRC #4103
Question Re: How to display Microsoft webcam on frc driver station camera view
Hello guys, i just tested the instruction above on the robot, the camera was on but no images appeared on the FRC control panel. How do I solve that problem?
Unread 15-01-2015, 18:56
FRC #4103
PS: the blue light on the Microsoft HD Camera 3000 flashes twice but turns off after that.
Unread 18-01-2015, 09:13
Was the camera plugged in when you booted the roboRIO? If not, I would try that. And make sure you have selected USB HW or USB SW on the dashboard.
