Go to Post The problem is though, as long as the teams are allowed to work on their robots on Thursday, they will, and they'll never learn to finish it before the event. - sanddrag [more]
View Poll Results: Is eclipse working for you?
Is it difficult to learn 1 100.00%
Was there a lot of work lost due to loss of netbeans? 0 0%
Voters: 1. You may not vote on this poll
Unread 13-01-2015, 20:46
Tparbotmail Tparbotmail is offline
FRC #3944
Tparbotmail is an unknown quantity at this point
Build path specifies execution environment javase-1.6
In eclipse I am getting
Build path specifies execution environment JavaSE-1.6. There are no jre's installed in the workspace that are strictly compatible with this environment.
Any thoughts on how to fix it so the warning goes away?
Unread 13-01-2015, 23:11
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Build path specifies execution environment javase-1.6
Make sure to configure your PATH and JAVA_HOME enviroment variables!
Unread 14-01-2015, 01:14
FRC #3944
Thank you for taking the time to reply. After my post, I did more searching and found this note on stackflow. It explained the process.
http://stackoverflow.com/questions/1...ava-build-path
It seems to me that it was a bug since when I expanded the list of libraries under Java 1.6 they were all 1.8 libs. That is why I suspect a bug. I followed those instructions and it worked.
