Go to Post Injuries can come out of no where. I know this is only a robotics competition but the injury doesnt care where or what you are doing. - nightrenegade00 [more]
Unread 09-01-2015, 22:51
ming08108 ming08108 is offline
FRC #4795
ming08108 is an unknown quantity at this point
roboRio Java installer stuck on untarring
Anybody else having this issue?
Specifically the java installer in /wpilib/tools gets stuck on untarring. The progress bar stops moving. I lets it run for more than 30 minutes and no progress is made.
Unread 09-01-2015, 23:27
majesticfish majesticfish is offline
AKA: Sean Yu
FRC #0948 (NRG)
majesticfish is an unknown quantity at this point
Re: roboRio Java installer stuck on untarring
Hi
I'm having the exact same problem. It simply gets stuck after connecting. I've looked into this with wireshark and it seems that after acknowledging the roborio, no more packets are sent through the interface.
Unread 09-01-2015, 23:31
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
I had a similar issue. Power cycling the rRIO fixed the issue for me.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 09-01-2015, 23:35
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Originally Posted by majesticfish View Post
Hi
The installer makes a log file, located in /wpilib/tools/logs/javainstaller.log. Could you please post that log?
Unread 10-01-2015, 01:25
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
When in doubt cycle power! Or reflash the firmware on the robotRIO. Then Try it.
Unread 10-01-2015, 12:45
AKA: Sean Yu
FRC #0948 (NRG)
Hi. I fixed the problem by imaging the roborio.
Unread 10-01-2015, 14:07
FRC #4795
09/Jan/2015 16:58:08,931- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/hijrah-config-umalqura.properties, putting tar entry is JRE/lib/hijrah-config-umalqura.properties
09/Jan/2015 16:58:08,932- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/jce.jar, putting tar entry is JRE/lib/jce.jar
09/Jan/2015 16:58:08,938- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/jsse.jar, putting tar entry is JRE/lib/jsse.jar
09/Jan/2015 16:58:08,954- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/jvm.hprof.txt, putting tar entry is JRE/lib/jvm.hprof.txt
09/Jan/2015 16:58:08,954- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/logging.properties, putting tar entry is JRE/lib/logging.properties
09/Jan/2015 16:58:08,955- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/meta-index, putting tar entry is JRE/lib/meta-index
09/Jan/2015 16:58:08,955- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/net.properties, putting tar entry is JRE/lib/net.properties
09/Jan/2015 16:58:08,956- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/resources.jar, putting tar entry is JRE/lib/resources.jar
09/Jan/2015 16:58:08,983- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/rt.jar, putting tar entry is JRE/lib/rt.jar
09/Jan/2015 16:58:09,660- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security, putting tar entry is JRE/lib/security
09/Jan/2015 16:58:09,660- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/blacklist, putting tar entry is JRE/lib/security/blacklist
09/Jan/2015 16:58:09,661- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/cacerts, putting tar entry is JRE/lib/security/cacerts
09/Jan/2015 16:58:09,664- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/java.policy, putting tar entry is JRE/lib/security/java.policy
09/Jan/2015 16:58:09,664- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/java.security, putting tar entry is JRE/lib/security/java.security
09/Jan/2015 16:58:09,665- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/local_policy.jar, putting tar entry is JRE/lib/security/local_policy.jar
09/Jan/2015 16:58:09,666- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/trusted.libraries, putting tar entry is JRE/lib/security/trusted.libraries
09/Jan/2015 16:58:09,666- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/US_export_policy.jar, putting tar entry is JRE/lib/security/US_export_policy.jar
09/Jan/2015 16:58:09,666- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/tzdb.dat, putting tar entry is JRE/lib/tzdb.dat
09/Jan/2015 16:58:09,671- DeployController: Processing file /Users/a/wpilib/tools/JRE/release, putting tar entry is JRE/release
09/Jan/2015 16:58:09,767- DeployController: Failure to send JRE to the roboRio
com.jcraft.jsch.JSchException: java.net.ConnectException: Connection refused
at com.jcraft.jsch.Util.createSocket(Util.java:349) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:215) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:183) ~[java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController.lambda$initialize$10(DeployControlle r.java:85) [java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController$$Lambda$165/216870574.run(Unknown Source) [java-installer.jar:?]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_25]
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.doConnect(Abstrac tPlainSocketImpl.java:345) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connectToAddress( AbstractPlainSocketImpl.java:206) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connect(AbstractP lainSocketImpl.java:188) ~[?:1.8.0_25]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.j ava:392) ~[?:1.8.0_25]
at java.net.Socket.connect(Socket.java:589) ~[?:1.8.0_25]
at java.net.Socket.connect(Socket.java:538) ~[?:1.8.0_25]
at java.net.Socket.<init>(Socket.java:434) ~[?:1.8.0_25]
at java.net.Socket.<init>(Socket.java:211) ~[?:1.8.0_25]
at com.jcraft.jsch.Util.createSocket(Util.java:343) ~[java-installer.jar:?]
... 5 more
10/Jan/2015 12:47:19,742- MainApp: Exiting installer from popup
Unread 10-01-2015, 14:41
WPILib Developer
FRC #0190
That looks like the roboRIO is not imaged. Could you try to format it with the ni image tool and then try to install Java again?
Unread 10-01-2015, 15:13
FRC #4795
I imaged it but I guess I can reset and try it again from the beginning on monday. Will let you know how it goes.
Unread 13-01-2015, 22:20
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
I had the same problem. If imaging does not fix the problem, ensure that you are connected to the roboRIO network. You cannot just use the USB.
Unread 13-01-2015, 22:24
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Honestly, the entire Java installer seemed fairly problematic. Make sure you're running it as administrator and make sure that your roboRIO is imaged and you should be fine.
Unread 13-01-2015, 22:36
WPILib Developer
FRC #0190
We tested it on all network connections, it will fall back to the static USB and old-style 10.te.am.2 ip address if it can't find the roboRIO via mDNS.
What was overly problematic? Is there anything I can change to make it easier to use?
Unread 14-01-2015, 10:46
FRC #4795
I had problems with imaging and had to call NI support. They told me to re image it over ethernet and that fixed the issue for some reason. Anybody know why?
Unread 14-01-2015, 17:23
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
I have no idea why. This happened to me as well when I was attempting to install off a flash drive. Once I put the file on my computer instead, it inexplicably worked.
Unread 17-01-2015, 15:05
katabeta katabeta is offline
FRC #5499
katabeta is an unknown quantity at this point
Had the same problem. Doing everything over ethernet and re-imaging the roboRio fixed it.
