Program robot code on Linux
Has anyone succeed running eclipse on Linux with WPILib ?
And which apt-get should I use ? Last edited by Kingston951 : 01-13-2015 at 04:13 PM. |
Re: Program robot code on Linux
Most of the WPILib team uses Linux, it works fine for us. apt is a command line tool for installing packages. You need to use it to install the toolchains on Linux. Follow the instructions here: http://first.wpi.edu/FRC/roborio/too...0Toolchain.txt
