Go to Post Yes, no more dancing. Robots is serious business :rolleyes: - wilsonmw04 [more]
View Poll Results: Is eclipse working for you?
Is it difficult to learn 1 100.00%
Was there a lot of work lost due to loss of netbeans? 0 0%
Voters: 1. You may not vote on this poll
Unread 13-01-2015, 20:46
Tparbotmail Tparbotmail is offline
FRC #3944
Tparbotmail is an unknown quantity at this point
Build path specifies execution environment javase-1.6
In eclipse I am getting
Build path specifies execution environment JavaSE-1.6. There are no jre's installed in the workspace that are strictly compatible with this environment.
Any thoughts on how to fix it so the warning goes away?
Unread 13-01-2015, 23:11
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Build path specifies execution environment javase-1.6
Make sure to configure your PATH and JAVA_HOME enviroment variables!
Unread 14-01-2015, 01:14
FRC #3944
Thank you for taking the time to reply. After my post, I did more searching and found this note on stackflow. It explained the process.
http://stackoverflow.com/questions/1...ava-build-path
It seems to me that it was a bug since when I expanded the list of libraries under Java 1.6 they were all 1.8 libs. That is why I suspect a bug. I followed those instructions and it worked.
