Go to Post "Wow, smells like... physics" - Anna B. [more]
Unread 14-01-2015, 01:31
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
pic: Angle Grinder Carnage
Unread 14-01-2015, 01:33
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
Re: pic: Angle Grinder Carnage
Its always been my rule to have a full face shield on when using any type of grinder/sander/cutoff saw. Not to stop sparks and the like but because those things blow up and when they do they don't show it sometimes and could really hurt some one.
Unread 14-01-2015, 02:19
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
I could be wrong, (please somebody correct me if I am) but I am pretty sure you are not supposed to grind aluminum with that type of abrasive disc. Grinding aluminum can gum those up and cause them to explode like that because it gets in the pores of the disc and causes it to expand. Then again, somebody please correct me if I am wrong.
Unread 14-01-2015, 02:20
T^2 T^2 is offline
FRC #5499
I once burned a hole through one of my shirts by leaning too close to the sparks. Good times.
You're not wrong.
Unread 14-01-2015, 02:53
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I learned of this phenomenon on regular bench grinder and surface grinders, but I've (thankfully) never seen it happen. I heard that the aluminum gums it up, causing it to just rub and not cut, heat up, and explode.
In any case you might want to invest in a decent bandsaw for aluminum cutting. Easy and versatile.
Unread 14-01-2015, 08:25
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Speaking from experience - ALWAYS anticipate failures from angle grinders/cutters like this one. They happen routinely, and can be caused by the slightest amount of mis-use.
What was this cutter being used to cut? How experienced was the operator? What type of blade was it?
This is correct, at least in principle. Abrasive wheels are generally not designed for aluminum (I've never seen one anyway!) and should not be used to cut aluminum for a variety of reasons. Cutting discs should only be used to cut the materials they're rated for.
I don't think it's because aluminum 'gets into the pores' of the cutting wheels. I believe its because aluminum adheres to the disc, preventing the disc from cutting properly and causing catastrophic heat build-up in the disc from friction.
This. This. This.
Even with the blade guard they can still cause a lot of damage. A friend of mine wound up needed 40 stitches when a blade like this shattered and tore into his face. He was wearing safety glasses, so he can still use his eyes, but it still really messed him up.
Unread 14-01-2015, 11:01
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
While you are right, this doesn't look like a fiber based grinding wheel. To me it looks like a stamped metal wheel with some kind of coating such as carbide or diamond. Similar to this.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 14-01-2015, 11:30
ms123132 ms123132 is offline
None #0195
ms123132 is an unknown quantity at this point
Safety FIRST!
I am apart of my teams manufacturing team and I do have to say that being safe while working with robots is something we take a lot of time to enforce. Always be prapared for anything catastrophic to happen because sometimes it could be life threatening! Safety SHOUT OUT FROM 195!!!
Unread 20-01-2015, 12:50
brynnanotbrenda brynnanotbrenda is offline
FRC #4458
brynnanotbrenda is an unknown quantity at this point
We had an incident where we were clamping some metal to a saw and the clamp ended up punching a hole in the saw. Ironically, it's now easier to clamp. It's a very nice clean hole, had you not been there you would think it was made like that.
Unread 20-01-2015, 13:35
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
You have a few choices grinding Aluminum. We use a bench sander & sanding disks on our angle grinder rather than grinding. Flapper wheels work also.
1(Probably best ) use wheels rated for Aluminum.
2 Use lots of lubricant like WD-40. Never done this. I am told that it is messy.
3 Don't let the wheel load up. Which will require frequent redressing. Not the best of ideas.
