Go to Post Clearly they're releasing the game hint on 12/21/12 because they know the world's going to end, and they want to keep FIRSTers happy and distracted until the very end. - Kevin Sevcik [more]
Unread 14-01-2015, 09:52
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
Autonomous Mode
While in autonomous mode runs do TelOp and Timed Tasked also run. I would really like to be able to use are code from TelOp and Timed Tasked to do autonomous but i am not sure that would work
Unread 14-01-2015, 09:54
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Autonomous Mode
I believe your timed tasks will run, but teleop will not.
Unread 14-01-2015, 09:58
TylerStaudigel's Avatar
TylerStaudigel TylerStaudigel is offline
FRC #0144 (R.O.C.K)
TylerStaudigel is an unknown quantity at this point
Re: Autonomous Mode
Agreed. Tele-op will only run when that mode is enabled. What you can do if you want to share data between modes is create a global variable to send it where it needs to go. You can place the vi for your sensor in either the timed tasks section or directly under the main control loop if you are using the default example. Good luck this season.
Unread 14-01-2015, 10:03
Bpk9p4's Avatar
FRC #1756
Re: Autonomous Mode
thanks for the quick response. I was thinking that was true but wanted to double check.
Unread 14-01-2015, 12:30
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Re: Autonomous Mode
Just so you have an idea on what runs and when, take a look into the Main.vi. You shouldn't need to edit anything in it, but you will see that autonomous only executes once, while periodic tasks runs at startup and teleop runs 20 times a second. There is of course more to it, but it'll give you a good idea of what code and loops are running at any given time.
Unread 14-01-2015, 14:26
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: Autonomous Mode
What we usually do (and what I would recommend), is that you put any software that you intend to use in both teleop and auton in the periodic tasks VI. You can then pass data from auton and teleop to periodic tasks with global variables.
That may not make sense at first so I'll give an example.
Let's say you have a lifting mechanism to lift the totes. You decide that it would be ideal to command your lift to a height (using presets on buttons) and use a PID to control the lift to the commanded height. At the same time, it would make sense for autonomous to command the lift to a height and use a PID to control the lift to the commanded height.
Since both your autonomous strategy and your teleop strategy both rely on commanded heights and a PID, it would make sense to move your lift control code to periodic tasks so it can be shared by autonomous and teleop. You could then create a global variable called "LiftHeightCommand" that is the set point of the PID. In teleop, do your button processing to decide on the commanded lift height and assign the output of your logic to LiftHeightCommand. In autonomous, just set LiftHeightCommand directly.
Unread 15-01-2015, 06:59
Re: Autonomous Mode
Good advice already. I'll add just one thing.
If the code will execute quickly. If it is reading sensors and comparing to some limit, for example, you can also make that code into a subVI and call the subVI from auto, tele, and periodic too if that makes sense.
If the code will wait for a mechanism to move, or time a mechanism's movement, you do not want to put it into teleOp, or it will prevent the next joystick inputs from being read on time.
Greg McKaskle
