Go to Post So I thought to myself "Man, I wish I was a part of a large technically minded community... oh... right..." - BordomBeThyName [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 13-01-2015, 16:32
Back after 4 years off
FRC #5279
REV V-groove Ball Bearing Weight
We are waiting for the REV Parts to come back in stock from AndyMark, but have a question while we are waiting.
http://www.andymark.com/product-p/am-2914.htm
The weight listed on AndyMark is .86 lbs, this seems extremely heavy to me. Other similar bearings list their weights as 1.4 ounces, which is much closer to .086 lbs. I am hoping this is a typo on the AndyMark site, but I wanted some one to confirm.
We are going to use 24 of these on our bot, and 20.64 lbs seems crazy, I am hoping it is closer to 2 lbs than 20.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 13-01-2015, 16:47
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Re: REV V-groove Ball Bearing Weight
Another website lists RM2ZZ bearings as 40 grams which is .088 lbs
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 13-01-2015, 20:42
Batterink Batterink is offline
FRC #4519
Batterink is an unknown quantity at this point
Since these are currently out of stock, is there any reason to use RM2ZZ bearings instead of RM2-2RS bearings?
Unread 14-01-2015, 09:05
FRC #5279
I don't see any difference in dimensions, but I am not an expert on bearings.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 14-01-2015, 11:04
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
I also looked it up from various sources and I believe it is missing a zero (.084 instead of .84)
Looking at http://www.revrobotics.com/product/rev-29-1014/ it is a RM2ZZ size. As others have said the RM2ZZ is around .084 pounds.
Unread 14-01-2015, 11:25
BryceKarlins's Avatar
BryceKarlins BryceKarlins is offline
Video Production Junkie
FRC #1261 (RoboLions)
Team Role: Electrical
BryceKarlins is on a distinguished road
That does seem to be excessive. I think we have some of these in our build site; I'll check this afternoon, and update with weight.
Unread 14-01-2015, 12:29
REVving up for a new season
FRC #2848 (All-sparks)
I can confirm, the weight is .084, it is just a typo.
Also they will be back in stock at AndyMark in the next couple days. RM2ZZ is a common bearing that you can get anywhere if you need it right away (but we are the lowest cost source that I could find anywhere online if you can afford to wait.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 14-01-2015, 14:04
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
What about the bushings?
Unread 14-01-2015, 14:08
FRC #5279
I spoke with both Greg and the people at AndyMark, bushings should be in today, and continue to trickle in over the next few days.
That being said AndyMark now lists them as back in stock on Saturday.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 14-01-2015, 14:45
Yes the bushings should be received this week, but the qty is very limited. If you are looking for another solution and have a lathe, making them is not hard our drawing is on the web. http://www.revrobotics.com/wp-conten...1029-DR-00.pdf Just start with a piece of 1/2 hex. To make the eccentric hole take it to a drill press or mill.
Another option for construction is drilling out 3/8 bolts. The amount of center offset is not that critical as long as you have enough flexibility that it can engage. For the concentric side, just use a 3/8 bolt and drill out the mounting plate.
Lastly another option is to buy the ones from Bishop-Wisecarver. They are more expensive, but available right now if you need them. The REV v-groove bearing system is compatible with their "Size 2" system. You might need to add a washer or spacer to get the alignment correct, but they will work.
Eccentric bushing - BWC Part number - BX2SS Price - 8.54
Concentric Bushing - BWC part number - B2SS Price - 4.18
I am sorry specifically about these bushings, 100% of them arrived to me out of spec from our mfg(so the bearings wouldn't fit), they are replacing them with new bushings but in the meanwhile we are re-working them (I am literally standing a lathe working on every single one).
Greg
Unread 14-01-2015, 15:22
AKA: -matto-
FRC #1410 (Kraken)
The 1" REV rails and Vee bearings show an expected date on 1/26. Since I can't back-order from AndyMark, I am hesitant to order the bushings and plates on Friday 1/16, then wait 10 more days in hopes of getting the rail.
Greg - can you give us an idea of what quantities are heading to from the manufacturer to AndyMark and when? The new REV extrusion system looks awesome, but if I can't get it earlier it will have to wait for the offseason to test. Good luck with your lathe work (I have a very deep personal dislike for poor manufacturing QA/QC for tight tolerance machined parts).
-matto-
Unread 14-01-2015, 22:10
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Thanks for the part print! I hadn't seen that on your website yet. Tonight I had a student download the assembly that was posted, open the .step file in solidworks, use the feature recognition tools, and then make a 2-D part print out of it for our Precision Machining class because they are going to help us out in making these. Now I have my answer key!!!
Good luck with the lathe work and thanks for being sooo dedicated! My local salesman for 80/20 was in today and he loves your stuff! He may be getting in contact with you....
