Thread Tools |
Rating:
Display Modes |
Looking for Lead Screws
Hi! We are looking for a lead screw for our robot. With the math we did we would need a 3/4" diameter screw with 2 threads per inch to reach our optimal speed. We are having a lot of trouble finding a lead screw that we could use and were wondering if anyone had any suggestions! Thank you, and we will see you at the competition!
Re: Looking for Lead Screws
Take a look at McMaster-Carr: http://www.mcmaster.com/#acme-precis...screws/=vgs0pf |
3/4 sounds like a massive lead screw to me but IDK your application. For that kind of speed you're most likely going to need a multi threaded rod. If I'm understanding you correctly you need 1/2in of travel per rotation. McMaster has threaded rods with that spec :
http://www.mcmaster.com/#99030a500/=vgs23q That is also available in a 6ft length. |
You must learn the ways of the Master, if you're to come with me to Eliminations.
Thank You for the help!
For the best price, buy from amazon.com. If you have prime, you get free shipping too!
As others have said a 3/4" lead screw is more than likely overkill. We lifted our entire robot with a huge factor of safety with two 1/2" diameter lead screws. |
#7
The reason we were looking for 3/4 is for speed and torque purposes. With the current design we would go around 20 ft per second.
#8
Haydon-Kerk has a large selection of lead screws. We used one last year with 8 starts and 2 inches of travel per revolution.
They're one of our sponsors. Maybe you can get them to sponsor you too? Last edited by electroken : 14-01-2015 at 16:23. Reason: Fewer missing words |
#9
I'm not sure on the math behind the torque required for different diameters but I think the torque is dependent on the travel/rev not diameter. There are smaller diameters available in .5in/rev that would probably be a lot cheeper at lighter.
#10
20 ft per second? Are we talking Vertical motion? that is very fast for our applications.
#11
20 ft per second is what we had calculated. We have a mentor who works with them often and he helped us figure it out.
#12
Maybe you mean 20 in. per second?
#13
I'd recommend you post your application and math here. I just went through this last night for a different application, and I don't mind reviewing your numbers.
We're considering using them in part as a pincher closure. I'm going to run 3/8"-8, 2start rod at ~ 3 inch/sec closure speed on each of the two arms for 6 inch/sec closure speed total. It is more than adequate from a loading standpoint. The only reason we would want to consider bumping up to a larger diameter would be to more easily support it from a single end without too much whip in the free end... or I might just support both ends and go with 3/8". Long story short, double check your numbers. These aren't 100% efficient devices, make sure you will have enough power to drive them in your application. |
#14
Yea guess i need some sleep, I think i got confused since we were looking at some that did feet per minute.
#15
You may be right that you actually need such a crazy thick lead screw in this case. For high speed stuff, I recommend a McMaster (or amazon equivalent) 1/2"-8 lead screw with 8 starts, resulting in a 1" of travel per rotation. These are the fastest commonly available lead screws you can buy. However, the concern your mentor has is likely due to critical speed. A lead screw can only spin so fast before it starts to vibrate like crazy and destroy itself. When we lifted our robot's weight, we drove the nut instead of the screw, so the screw moved relative to the robot. With this configuration, critical speed isn't a concern. This configuration doesn't work so well for elevators, where you want to drive the screw and let the nut move up and down. I don't remember what the exact critical speed for a 1/2" lead screw is that's well supported at both ends and is around 70" tall, but IIRC, it was in the ballpark of 600 rpm. That's 10 inches per second, which is slower than what you wanted. My recommendation is not to use a lead screw if you plan to have a 70" tall elevator, but if you plan to have a shorter elevator (3 feet or so), go with a 1/2" lead screw. The critical speed increases quickly (meaning you can go faster) as you decrease the unsupported lenght of the lead screw. |
