Go to Post I have photos of students working the lathe dressed for a concert! Makes me wish for a formal dress night at robotics. - Mark McLeod [more]
Unread 14-01-2015, 15:37
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Taking your robot to the field
From the 1/13/14 game update:
While there is no corresponding change to the Game Manual, the LRI’s also wanted to make sure that all teams are aware that ROBOTs must fit in, and be transported in, a single
TRANSPORT CONFIGURATION volume at the event. This doesn’t mean the exact configuration of the robot within that volume must be the same every time, but that every time
a team is moving their robot as required under T6, they must do so using only one contiguous volume of the size and orientation specified
I am not sure how rigorously this will be enforced, but. This means if you have detachable arms or a mast, you cannot have some one carry a piece separate from the robot. It will all have to be in the robot transport volume. Safe transport will mean designing the robot so the detached pieces are not precariously crammed into the transport volume. It will make for some interesting maneuvers if it is required from the field to the cart.
Unread 14-01-2015, 15:54
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Taking your robot to the field
If you take PVC pipe and slice it into pieces maybe 1" in length, then make two cuts separating it from an 'O' into a 'C', depending on the diameter of the pipe and geometry of a piece, it makes a nice clip that is super light, easy to mount, and can hold pieces securely, while being easy to release
Unread 14-01-2015, 16:55
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
I expect to see a whole lot more Que box robot construction than usual this year.
Unread 14-01-2015, 17:28
MasterMentor's Avatar
MasterMentor MasterMentor is offline
TheGreatGonzo
AKA: George Gonzo
MasterMentor will become famous soon enough
Even though the rules say that robots have to stay in the TRANSPORT CONFIGURATION until they get onto the field? Or are you worried more about "preparation for getting onto the field", kinda like people untying their shoes while in the security line at the airport in preparation for taking them off at the security station?
Unread 14-01-2015, 19:18
Memento Vitam's Avatar
Memento Vitam Memento Vitam is offline
Momento Vitam
FRC #5484 (Momento Vitam)
Team Role: Team Spirit / Cheering
Rookie Year: 2015
Memento Vitam is an unknown quantity at this point
Can it be in pieces?
Unread 14-01-2015, 22:19
Doug Frisk's Avatar
Doug Frisk Doug Frisk is offline
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
As long as the pieces fit in a box that's no larger than the transport configuration.
That said, you have 60 seconds to assemble the robot on the field. I'm sure the FTAs and Refs will be forgiving the first few rounds, but I expect that once the matches are 20 minutes behind schedule they'll be making teams clear the field and go, ready or not.
Unread 15-01-2015, 09:07
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
This sounds backwards, but I really hope they're firm about the time limit from the beginning. Set your robot down, 60 seconds to put it together, clear the field.
If you're giving teams freedom in their first few matches they'll adjust to that. Once you tighten it up they'll get annoyed/have to change their system. I'd rather have to start sub-60 seconds and never, ever - not even once - have the chance to go over it.
My advice? Practice your NASCAR-pit-speed assembly early, and often. Right now we only have one assembly that may stick outside the transport config, and if it does you can be sure our Drive Team will spend a good chunk of their practice getting that stuff on & off the robot as efficiently as possible.
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
Unread 15-01-2015, 09:41
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I hope our robot design works, because I'm pretty sure it will fit in the transport configuration without having to do anything to it, aside from make sure two mechanisms are at the end of their travel in the right direction.
Unread 15-01-2015, 10:18
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
I would be disappointed if the rule were not to be enforced... Abiding by it while giving the robot the functionality that we desire adds a layer of complexity to the build... I guess I could understand giving some "flexibility" to teams at the beginning of their week 1-3 events, but it would have to be limited lest it give an advantage to teams that disregarded the rule as they were designing their bot.
